Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
MOPAR DECALS
Old 07-06-2013, 09:18 AM
bseling's Avatar
bseling bseling is offline
Vehicle: 2014 Ram 2500
Rep:60
bseling will become famous soon enough
Default 4x4 in Sand
Alright fellas, I need some help...
Decided to drive my truck onto the beach and noticed some issues.
Here's what happened:
- put truck in 4 auto.
- started driving but as the dry sand got a little deeper (up the the wheel), I started to get stuck. The wheels weren't spinning and the truck was shaking a little.
- I put in 4 lock, no help.
- Turned off Traction control, no help.
After spinning and rocking, I started to smell clutch...
Anyways: why was I struggling so much? I have the stock tires with 30k on them, so that could be part of the problem? Makes me want to get some new 35s!
I'm from Colorado, and the truck is awesome in the snow. What's going on? Driver error?
I at least got a good pic of the truck on the beach....
Old 07-06-2013, 09:33 AM
gs283020's Avatar
gs283020 gs283020 is offline
Vehicle: 2011 Dodge Ram 1500 Big Horn
Color: Mineral Gray Metallic
Rep:54
gs283020 will become famous soon enough
The problem is driving in the sand even if you get 35s. It is the footprint that makes the difference. In sand the more tire on the ground the better. You want to distribute the weight so that it doesn't dig in and you sort if coast across the sand instead of digging in. Air down your tires to around 22 psi, keep your momentum and you should be fine. I am sure there are much more experienced people to chime in. This is what I have learned.
2011 Ram 1500 Big Horn 5.7L HEMI
Old 07-06-2013, 10:24 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:408
Airing down is key. Air way down.
Old 07-06-2013, 10:29 AM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
When you say that the wheels weren't spinning, were the fronts not spinning, or none?
35s won't help if the front axle isn't engaging. Did you give the engine a good tromp to try and break loose? Probably worth looking in to.
In terms of driving in sand, you typically want to air down your tires to 18-22PSI, and you want to keep your moving speed up. In the past, I've actually aired down to 15 psi to get me out of situations in the desert.
Old 07-06-2013, 10:56 AM
rts551 rts551 is offline
Vehicle: 2013 RAM
Trim Level: SLT Big Horn
Color: copper
rts551 is on a distinguished road
Air Down! but regardless of air pressure, in 4 lock front and rear wheels should have been spinning.
Old 07-06-2013, 09:23 PM
RPM666's Avatar
RPM666 RPM666 is offline
Vehicle: 2012 RAM 1500 LL Limited 4x4
Color: True Blue
Rep:363
RPM666 is just really niceRPM666 is just really niceRPM666 is just really niceRPM666 is just really nice
Stock tires on beach is a no-no!
Wrangler HP = kick in pants.
I'm very interested in more details on 4Auto and no tires spinning...
S&B CAI // Flowmaster 50 Series HD // Bilstein 5100's @ 2.8" // Lockpick V5 // Hypertech Interceptor // Cabin filter mod // BP Polished Catch Can // TonnoPro LoRoll Cover // 4 Digit Combo Console Vault // Escort 8500 X50 Blue // GumCreek Vehicle Holster
Old 07-08-2013, 04:01 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
Those stock tires aren't even good on the street stay off the sand with the for sure. I was down at the beach with no issues in my truck 4lock. I am running 285/60r20 duratracs and only had one issue with a soft dune and a heavy ram some wider tires aired down may or may not have helped. I take mine through mid, sand, dirt, some clayish dirt and have no problems at all. Definitely get some better tires. A level and 33x12.5's would give you a lot more bite than I have but I am happy with my tires and they fit great and are quiet until you come out of some mud and they start cleaning themselves out on payment and tossing chunks of it everywhere.
Old 07-08-2013, 03:35 PM
shaner82's Avatar
shaner82 shaner82 is offline
Vehicle: 2013 Dodge Ram Sport
Rep:47
shaner82 is on a distinguished road
That's weird that the tires weren't even spinning. I can't imagine the sand being so heavy that it prevents the tires from spinning. Something doesn't sound right
Old 07-09-2013, 12:37 AM
09HemiCrew 09HemiCrew is offline
Vehicle: 2009 Dodge Ram
Rep:75
09HemiCrew will become famous soon enough
I had this happen in an old diesel suburban when I was younger (6.2 turd). I had to put it in 4 low in order to have enough torque to get the tires spinning. Once I could spin the tires, it crawled through no problem. No experience with sand in my Ram, but it seems like it would have enough snort. I could see having some issues with auto 4 and traction control, but you said you tried with ESC off and 4 high. Weird.
2009 Crew Cab 4x4 Laramie - 4.56 gears, Detroit Truetrac, Diablosport Trinity
Old 07-09-2013, 09:38 AM
DRX350's Avatar
Color: Blue-ish
Rep:118
I'm sorry, but that's not right. 4x4 should be able to get a truck out of nearly anything with nearly ANY tires. I have Uniroyal all-purpose tires on mine, and I had no problem in DEEP sand. If I came close to getting bogged down, I just gave it more throttle, and I stayed right on top of the sand.
