Old 07-06-2013, 11:35 PM
sweetfarms sweetfarms is offline
Vehicle: 97 dodge 3500 diesel 4x4
Color: red
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
sweetfarms is on a distinguished road
Default 97 Dodge 3500 under water. Can I save it?
I bought the truck new with the Diesel engine and 5 speed. Only 67K miles. To make a long story short, I get stuck on the road going to our river sandbar and could not get it out before the river came up due to a flash flood upstream. Any suggestions on what to do next? Thanks, Ken
Old 07-07-2013, 12:00 AM
Rep:2642
you can rebuild a diesel engine enough times to drive a million miles
as long as you take care of it, it will take care of you
I am not a diesel mechanic, but i am thinking
if your engine was under water, you may have to pull the Head off & check it out for cracks & cleanliness in the cylinders
the fuel system may have to be flushed & the tank emptied & cleaned
injectors will need to be checked out
oil & filter changed
suspension will need to be greased at a minimum
you will need to check out & grease the axle bearings
Old 07-07-2013, 12:28 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Plenty of drying time.
Drain and replace all lube in driveline (including rear axle) parts and engine.
Fuel system will need a complete purging. DO NOT spin engine over until you are certain there is no water in the cylinders. If you do and have water it'll blow the head off or destroy the rods, pistons, and crank, possibly kick a rod out the side of the block.
Old 07-07-2013, 01:41 PM
Asur Asur is offline
Vehicle: .
Rep:4373
How high did the water hit the truck, was is submerged? or half way? how long ago was this and has anything been done to the truck since then?.
Old 07-07-2013, 02:33 PM
scrappy scrappy is offline
Vehicle: '12 ram 3500
Trim Level: laramie limited
Color: mineral grey
Rep:29
scrappy is on a distinguished road
Was it running when it was submerged? sounds like not but have to ask. also how deep?
correct if RUNNING, if not just get all the water out, change fluids, and go
the injection system will not pick up water if not running and also the head is also fine, no need to mess with that.
Old 07-07-2013, 02:52 PM
Color: red
Got over the cab yesterday and will continue to be under water until the river goes down. Probably 3-4 more days. Was not running. Ken
Old 07-07-2013, 03:15 PM
RPM666's Avatar
RPM666 RPM666 is offline
Vehicle: 2012 RAM 1500 LL Limited 4x4
Color: True Blue
Rep:363
RPM666 is just really niceRPM666 is just really niceRPM666 is just really niceRPM666 is just really nice
Wow that's crazy. Please take pictures while the water is slowly receding - this has to be documented!
I'm sure you'll have your hands full with the electrical systems and a very powerful wet\dry shopvac as well.
S&B CAI // Flowmaster 50 Series HD // Bilstein 5100's @ 2.8" // Lockpick V5 // Hypertech Interceptor // Cabin filter mod // BP Polished Catch Can // TonnoPro LoRoll Cover // 4 Digit Combo Console Vault // Escort 8500 X50 Blue // GumCreek Vehicle Holster
Old 07-07-2013, 03:18 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
I suggest getting a 3.0l v6 eco diesel in a few months heh.
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 07-07-2013, 05:39 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
that sucks, hopefully you can salvage the engine, rebuild ect, then find a nice clean 97 truck as close to yours as possible that needs an engine. imho, you will be dealing with "gremlins" caused by being under water for the rest of the trucks life.
Old 07-07-2013, 06:45 PM
Vehicle: .
Rep:4373
Everything in the interior will be trash, 5 days underwater will kill anything electrical, on top of that its not like the battery was pulled before it went under, yes you can save the engine, but anything attached to it will be a lost cause, if your insured , get some money for it and go buy a nice dry one, keep this one for spare parts, whatever you can salvage. JMO but when the river dies down and you see whats piled up inside the truck and everywhere else you will not want to hold on to that truck. Raging river vs truck, Mother nature always wins, again JMO.
