Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-08-2013, 10:07 AM
pick pick is offline
Vehicle: 1996 dodge ram 2500HD
Trim Level: SLT Laramie
Color: Aqua and clear White
pick is on a distinguished road
Default Coolant drain
How do I do a complete coolant drain? My owners manuel sez "open radiator petcock and also remove drain plugs in the block". Drain plugs? Do they mean the Frost plugs? No way am I about to punch out the frost plugs.
This is my first thread as a new member. Thanx guys !!
Old 07-08-2013, 12:28 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
On the bottom of the radiator there is a small valve pointing down with a white cap. I think yours gets turned clockwise as if to tighten it.
I'm not aware of any drains on the block, but maybe someone else does.
Old 07-08-2013, 05:38 PM
It appeared to be too much work to use the radiator drain valve, as the splash pan has to be removed. I drained it by removing the lower radiator hose which was easy to access. I only was able to drain ten quarts. The other 3/4 's must be in the block. That's a nutty set-up and I bet the engineer who thought that one up is still giggling when he thinks back on that deal.
Your comments appreciated.
Old 07-08-2013, 05:56 PM
Vehicle: 95
Rep:1776
I usually unhook the lower hose as you did. I love antifreeze in my arm-pit
Old 07-28-2013, 04:45 AM
tox's Avatar
tox tox is offline
Vehicle: 2000 Dodge Ram Sport
tox is on a distinguished road
When I did my plenum I never drained the block. I just put a hose onto the radiator valve so it didn't go everywhere and opened it up. It takes a long time to drain out though. I never bothered to look for a block drain plug, but I did take a free shop vac and suck some coolant out. The freeze plugs are different.
2000 Dodge Ram 1500 Sport 360 quad cab loaded. Kegger mod: http://goo.gl/hXl48Z
