Old 07-09-2013, 08:11 AM
quicksilve quicksilve is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Outdoorsman crew cab
Rep:17
quicksilve is on a distinguished road
Default Single exhaust to duals
Hey guys, got a 2012 outdoorsman that use to have a single exhaust out. Converted to a magnaflow dual cat back last year with a single in and dual out muffler. I'm pretty happy with the performance but was looking and getting into a DI/DO setup. Will I need to Cat's for this setup? Or can I use a DI/DO muffler and y-pipe off the Cat?. Looking to get the best performance for the best price.
Old 07-09-2013, 12:59 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Your truck already has two cats on it. One on each side just down from the exhaust manifolds. All you would have to do is cut off the Y-pipe and then run the dual pipes to your muffler.
You aren't going to gain much by doing that though... You'd be better off just swapping out the stock Y-pipe with an aftermarket Magnaflow one and keeping your SI/DO muffler. The other option would be to go to a true dual set up with an X-pipe but that will involve a full custom exhaust from the cats back.
