Old 07-09-2013, 11:19 AM
pick pick is offline
Vehicle: 1996 dodge ram 2500HD
Trim Level: SLT Laramie
Color: Aqua and clear White
pick is on a distinguished road
Default Tips for tranny fluid & filter change??
Gonna do a first time Auto tranny fluid and filter change. Never dropped a pan before. Any special tips that I need to know ??
Old 07-09-2013, 01:35 PM
RI99Ram's Avatar
RI99Ram RI99Ram is offline
Vehicle: 2001 Dodge Ram 2500
RI99Ram is on a distinguished road
This video covers a new model Dodge, but gives the basic idea. Be real careful when taking out the cover bolts as they can break if you put too much torque when they are rusted up. And leave a couple bolts in 1 corner so the pan comes down crooked to drain right into your catch basin. DO NOT try to take the pan down in 1 shot when full....it never ends well. Good Luck!
~ When All Else Fails...Use A Bigger Hammer ~
Old 07-09-2013, 02:56 PM
That is just the info I needed. Now with a little luck I'll be able to get the job done.
Thanks very much for your help. WOW..... What a great site.
Old 07-09-2013, 10:50 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Don't forget to adjust the bands. One is externally adjustable, but the other can only be adjusted AFTER you drop the pan.
Old 07-15-2013, 04:28 PM
Got her nearly done. Put in the 14 pan bolts and ready to tighten them.
QUESTION: How much torque in Ft/lbs ??
Old 07-15-2013, 04:44 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
If I remember correctly you do not want to over tighten the bolts because they will strip easy.
My rule of thumb is tighten until it is firm then just a small push more.
They aren't mean't to be torqued down hard.. that is why there are 14 of them.
Chrome... in moderation.
