Old 07-09-2013, 01:46 PM
Trsmovingtarget Trsmovingtarget is offline
Vehicle: 2011 Dodge Ram
Color: Blue
Trsmovingtarget is on a distinguished road
Default High pitch metal squeak coming from front end.
I have been dealing with this very high pitch squeak coming from my front end. It doesn't change with wheel speed so not a bearing. I hear it most on slightly rough roads when the tires are vibrating rather that full shock dipping motion. I have a two inch leveling kit installed on the front end. Could I be over-extending the front struts? Which are factory.
Old 07-10-2013, 04:14 PM
Divi Divi is offline
Vehicle: 2011 Ram 1500 Crew cab
Trim Level: Sport, loaded
Color: Obsidian Black Pearl
Rep:112
Divi will become famous soon enoughDivi will become famous soon enough
check your brake dust shields. bend them back a wee bit from the rotor. I had the same type of issue and it was the dust shields.
2011 Ram 1500 crew OBP, Airraid Cold air, Bestop roll up, Lockpick v5, custom carbon interior trim.
Old 07-13-2013, 04:19 PM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
I had this squeak as well. Turned out my blistein 5100's strut nut wasnt tight. Mine were so loose it clunked as well when I hit bumps. Took back to installer with a torgue spec sheet I found posted on this forum and he had to basically redo the 2-3 hour job at his cost. I believe mechanic used thread lock the second time around
I think there are threads on the blistein 5100 squeak as well. Not sure if its your issue but something to look into.
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
Old 07-15-2013, 03:42 PM
Color: Blue
Thanks for the info. Took the truck in today, will post up diagnosis when I get it.
Old 07-18-2013, 12:07 PM
Jmania44's Avatar
Jmania44 Jmania44 is offline
Trim Level: Big horn
Color: Green
Jmania44 is on a distinguished road
I would like to know what you find out because I'm having this same exact problem on mine. Only 20000 miles so I find it hard to believe its a strut going bad already
Old 07-24-2013, 12:36 AM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
any diagnosis yet???????
