Clunking noise; bad tie rod ends? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 08-08-2013, 10:57 AM
KyleKirk KyleKirk is offline
Vehicle: 2001 Dodge Ram 1500
KyleKirk is on a distinguished road
If you do remove it make certain you mark the location of the pivot bar on the upper to retain your caster/camber settings. Also might be a good idea, if you remove it to redo the control arm bushings. But you should be able to get a pickle fork in there and pound away otherwise. A puller is a mute point unless you are reusing the ball joint, or trying to save the boot, which gets replaced anyway.
