Old 07-09-2013, 11:16 PM
RamLove's Avatar
RamLove RamLove is offline
Vehicle: 1996 Dodge Ram 1500
RamLove is on a distinguished road
Exclamation Rebuild or not!?
My truck has been sluggish lately. It is a 1996 and it just doesn't seem to have the same power and get up as it used to. What can I do to liven it up a bit an a small budget. Hell, what could I do if I saved up enough money?
Should I rebuild it? It has 188,000 miles on it so I don't know if the engine just needs a thorough work through or if I am being paranoid.
Any advice or thoughts are appreciated!!
Old 07-15-2013, 06:24 PM
DRX350's Avatar
DRX350 DRX350 is offline
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
When's the last time you did a tune-up?
Other than that, You may want to try and Seafoam it...
Old 07-23-2013, 01:13 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
+1 tuneup: plugs, cap, rotor, wires
Double roller timing chain
Checked your plenum gasket condition?
How's your exhaust?
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 07-24-2013, 11:07 AM
RamLove's Avatar
I haven't done a tune-up in a very long time it seems.
I have not checked my plenum gasket. I am a tad broke at the moment so doing something that costs $120 is off the market currently.
And my exhaust was just gone through and the CAT was replaced.
Other than that, no big issues.
Old 07-25-2013, 09:51 PM
jabba974 jabba974 is offline
Vehicle: 1997 Dodge Ram 2500
Color: Driftwood Satin Metallic
jabba974 is on a distinguished road
Follow the K.I.S.S rule...keep it simple stupid...lol Plugs, wires, cap and rotor first! clean out the throttle body, run some fuel system cleaner through it, change the airfilter...And then drive it for a week and check your mileage...see where your at....if money permits, I added an MSD box to mine, and was very happy with the increase in milage and power...
On a side note...make sure your brakes aren't hanging up..that can rob alot of power, which I just found out after replacing the front brake hoses...
Old 07-26-2013, 07:44 PM
RamLove's Avatar
What do you mean by the brakes "hanging up"?
Old 08-02-2013, 12:42 AM
Sometimes the calipers will not release and cause the pads to drag on the rotors..if its real bad, it will feel like your hauling a trailer...
Old 08-02-2013, 11:18 AM
RamLove's Avatar
No, that's not happening. I just replaced the pads not too long ago and they were fine.
Old 08-04-2013, 03:38 AM
Mopartruckin Mopartruckin is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Sport Off-Road
Mopartruckin is on a distinguished road
+1 Seafoam worked great for turning back the clock on my truck. Amazing stuff
Old 08-11-2013, 01:13 AM
RamLove's Avatar
I am thinking about getting the Hughes Plenum fix kit and possibly doing the Kegger mod while I have the intake manifold off anyway. Would seafoam after that be a good idea or not?
