Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2012 Dodge Ram Forum
Old 07-10-2013, 03:12 PM
idefi idefi is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Limited
Rep:26
idefi is on a distinguished road
Default Anyone found a solution for the radio freezing? 730N
I did a search and others have mentioned having this problem, but I did not find any solution. It has happened about 4 times now where the backup camera comes on and will not turn off after putting it in drive. When this happens I can't control the radio at all and nothing works. It still shows the camera running and if I have the radio on, it will keep playing music but I can't change the volume or station. If I turn the truck off, the camera stays running the whole time, even when I close and lock the doors. The only way to get it to stop, that I have found, is either pull the radio fuse or turn the truck off for 10-15 min. Figured I would ask here before running to the dealership as I can't re-create the issue in front of them.
Ideas or fixes?
Old 07-10-2013, 06:02 PM
BlueRamMan34 BlueRamMan34 is offline
Vehicle: 2012 Dodge Ram Laramie
Color: True Blue Pearl
BlueRamMan34 is on a distinguished road
When it does it, take video on your phone to prove it. that's what I have done a couple of times to prove different things.
Old 07-11-2013, 05:33 PM
Trim Level: Limited
Rep:26
Good idea! I appreciate that.
Old 07-12-2013, 05:51 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
Which software rev do you have? There have been some updates.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
Old 07-13-2013, 02:08 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:736
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
why not let the dealer fix it under the warranty included with your truck.
