Step by Step Guide to General Cleaning/Maintenance - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-29-2013, 02:46 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
I refuse to follow any advice regarding detailing my truck, inside or outside , that does not mention anything about a COOL BEVERAGE!!!
Jay
Just kidding--excellent information--as usual.
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Old 08-29-2013, 07:20 PM
snrusnak's Avatar
snrusnak snrusnak is online now
Rep:1388
Thanks Primo!
What do you think of opti seal?
I wash my truck maybe 3 times a year, with dawn when I'm going to apply the sealer. I use a cheap car wash soap from walmart when not applying sealer. I don't do any of the other steps. Do you think this is providing decent protection? Mainly from the sun?
Thanks. All I really care about is protection, UV protection mainly.
Sean
Old 08-29-2013, 07:48 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
Originally Posted by Hermes1 View Post
I did enjoy it, although the leaf blower suggestion won't work for me because my leaf blower won't blow a dandelion apart Another story.
lol
Jay
well usually i do have picutres to accomodate what i write up...and there are always empty beers laying around!!! lol
Thanks Primo!
Opti seal is a great product and is very easy to use....Also any optimum product will give you great UV protection. you will see similar duarability and protection out of optimum car wax which is a real nice spray wax.
honestly though, if uv protection and low maintenence is your goal, cquartz or opti coat are great options...and more permanent.
Old 08-29-2013, 07:56 PM
snrusnak's Avatar
Rep:1388
They have to be machine applied though, correct?
Sean
Old 08-29-2013, 08:49 PM
Rep:912
no..totally opposite. apply by hand..
the machine part is to ensure the best possible polishing stage prior to application.
if your working by hand though for all steps 9polishing) then def stick to what works great, and that is opti seal or optimum car wax.
i also like aquawax, and menzerna powerlock for sealants...both again hand application, and because they are not "permanenet" types of products, the picture perfect finsihing stage is not as important as with the cqaurtz or opti coat.
Old 08-29-2013, 09:27 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Most Excellent write up, Primo. Reps for outstanding advise you provide to us amateur car washers.
Old 08-29-2013, 09:42 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
what are your waxing thought primo, on horizontal surfaces front to back and vertical surfaces top to bottom?? i'm sure you've tried a 1000 or so application methods, and if you've tried it have you noticed better light refraction?
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 08-29-2013, 09:44 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
by the way, package arrived in less than 24 hours!!!! sweet, thanx again!!!
Old 08-30-2013, 06:18 AM
Rep:912
thanks! i just hope they help!
I honestly dont use wax that often because of the great selection of sealants and coatings available nowadays. when i did use waxes though, i always applied them with the DA polisher. i found i was able to lay down a nice even thin coat that way.
but the straight line application method that you are describing is actually a preferred method for application (i I use it with sealants and coatings that i apply by hand). the "theory" is that if you were to instill and scratches or marring during the application process, that they would be less noticable because they were in a straight line, instead of circular pattern (or swirls).
Im not sure that either application method has less chance of instilling scratches over the other. in my opinion, if the product you are applying is non-abrasive, the car is clean, and the medium you are using to apply the wax/sealant is soft and non marring, then you should achieve the same results using either method.
glad to hear! let me know if you have any questions.
Old 08-30-2013, 11:17 PM
Leadfootluke Leadfootluke is offline
Vehicle: 1998 Dodge Dakota
Rep:276
Leadfootluke is a jewel in the roughLeadfootluke is a jewel in the roughLeadfootluke is a jewel in the rough
There is no difference in direction, but there could be a difference in overlapping, pressure, and products used.
Permanent coatings obviously take more time and thought, but even semi permanent coatings and sealants can create high spots. Directions generally include straight line passes in one direction, followed by perpendicular passes to create a hatched effect which ensures even coverage. Some waxes and sealants suggest a second coat to provide even coverage, whereas others discourage it because the solvents used in waxes/sealants can strip the previous coat, or conversely, create high spots.
Straight line does allow for better paint correction in the event that you do have debris caught under your applicator and induce marring.
