Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Engine Cleaning
Engine Cleaning Cleaning the Engine bay and under body. Degreasing etc.
Old 07-11-2013, 06:32 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
Default Step by Step Guide to Engine Detailing
ABSOLUTLEY REMEBER THIS TIP!!!!!
Do not wash the engine unless it is cool.
Step 1 Preparation
Cover/wrap any electrical component that might get wet while washing with a plastic bag (grocery bag) or saran wrap. Parts to cover include the distributor, alternator, fuse box (optional) and any exposed wiring connectors.
Step 2 Rinsing
In My opinion, a pressure washer is not needed and will only cause you grief. Using the garden hose, rinse the engine bay using low pressure. Just give a quick rinse of the engine bay, not blasting it, and keeping away from the areas of concern you previously covered. Go over each area of the engine and do not let the water run over the same spot for an extended amount of time. The goal is to just wet the area, and rinse any lose debris off.
Step 3 Cleaning
Use a good all purpose cleaner such as Duragloss APC or Meguiars APC. Simple Green can be used, but it has been reported to etch aluminum....I haven’t seen this happen myself, but others have reported it so be careful.
Spray your favourite APC throughout the engine bay. Let the APC dwell for a few minutes and it will start to break down the oil & grease on its own. Next, grab some various brushes and sponges, (detail brushes, Daytona wheel brushes, tooth brushes etc.) and give the engine a good scrub. Easily accessible areas can be cleaned with the sponge. (underside of the hood, valve cover, exposed paint, etc.) The harder to reach and dirtier areas are what the brush is for. It's fine to spray on a little more APC on areas that you need to while scrubbing.
Step 5 Rinsing
After you have finished scrubbing and the engine is degreased, rinse the engine bay, using low pressure and let the water run over the engine. You can do more scrubbing with the brushes, and even add a bit more APC to areas that you've missed or need a bit more work. Rinse thoroughly.
Step 6 Drying
Do not air dry the engine. Using some old MF towels, hand dry each part of the engine bay you can reach. Also some compressed air works good here. Just be mindful not blow the water into unwanted electrical areas. Unwrap the electrical components and use one of the more damp towels to wipe them down. Then dry them with another dry towel.
Step 7 Plastic & Hose Detail
To dress and protect the engine and hoses and other under-the-hood plastic, look to use Sonus Trim and Motor Kote, or another top quality product such as Meguiar's vinyl & rubber dressing or 303 aerospace protectant. I personally like the Sonus product because it has never attracted any dust or dirt..
If working with any product except the sonus product, spray the dressing directly onto the towel and then wipe down the hoses and other plastic. The sonus product works a bit differently.
Let the dressing dry before driving, and I suggest leaving the hood open in the driveway in the sun for a couple of hours to ensure it is dry.
Here are a couple pics of the last engine i did with some products listed above.
Old 07-17-2013, 06:37 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Another great write-up, primo.
Old 07-18-2013, 11:47 PM
browndawg's Avatar
browndawg browndawg is offline
Vehicle: 2012 ram 1500 4x4 express rcsb
Color: true blue pearl
Rep:101
browndawg will become famous soon enoughbrowndawg will become famous soon enough
personally I never clean my engine bay till right before I sell a vehicle. good write up though
Old 09-12-2013, 01:48 PM
iveyusmc iveyusmc is offline
Vehicle: 2006 Ram 1500
Trim Level: Texas Edition
Rep:12
iveyusmc is on a distinguished road
Im going to do this this week.
Old 09-12-2013, 01:58 PM
Rep:912
perfect! let us know how you make out!
Old 03-23-2014, 12:08 AM
Superduper Superduper is offline
Vehicle: 2013 Crew Cab
Superduper is on a distinguished road
Come wash mine!
Old 03-23-2014, 08:40 AM
Rep:912
lol...sure!
Old 03-23-2014, 08:58 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Primo, what are your comments on the Gunk heavy duty engine degreaser, it has good reviews and has always worked good for me?
Old 03-23-2014, 09:05 AM
Rep:912
Gunk works great IMO, but i like to use an APC that i can can control the dilution ratios.
i start at about 10:1 with some of the APC's I use, then if need be, i step it up from there. Gunk in the aerosol can is one strength, and usually i found i needed the whole can.
The APC's i use come in gallons, so it is very low cost, and some "CLAIM" environmentally safe.
Old 03-23-2014, 09:12 AM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^^ Makes sense. You coming to our Hamilton meet next Saturday?
