Garage door opener - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 07-12-2013, 09:11 AM
Clarkgriswald's Avatar
Clarkgriswald Clarkgriswald is offline
Vehicle: 2013 Dodge Ram Sport
Clarkgriswald is on a distinguished road
Default Garage door opener
For the life of me I can not get it programmed to the truck. First off do you need to have the truck running? I have cleared the channels and then held my GO a couple of inches from the home link but all the EVIC will say is that the button is trained. I have held the buttons for a couple of minutes too. What am I doing wrong?
Thanks for your help.
Old 07-12-2013, 09:35 AM
Monster5601 Monster5601 is offline
Vehicle: 15 Longhorn 3500
Trim Level: Longhorn
Color: Western brown
Rep:509
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
From what you are saying, it sounds like the RAM button was trained. When I trained my truck, it seemed the training was almost instantaneous.
Did you try to have your door opener learn the RAM button?
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
Old 07-12-2013, 09:39 AM
tev9999 tev9999 is offline
Trim Level: Outdoorsman
Color: Maximum Steel
Rep:39
tev9999 is on a distinguished road
Never had a problem with mine. I don't think the truck was running when I did it. I just held the button on the truck for about 10 seconds, then pressed the button on my opener's remote and held both for another 10 seconds or so. Never noticed any update message, but it worked on the first try.
Old 07-12-2013, 09:56 AM
Grimass Grimass is offline
Vehicle: Ram
Rep:76
Grimass will become famous soon enough
This. This. This. THIS!!!!!!!!!!!!!
There was another thread about this one here somewhere -- but so many people skip the step of pressing the button of a WORKING garage door opener at the same time wile programming!!!!
When you do it correctly, the EVIC will tell you.
Old 07-12-2013, 10:20 AM
shaner82's Avatar
shaner82 shaner82 is offline
Rep:47
shaner82 is on a distinguished road
1. Clear all your buttons in your truck
2. Hold the button in your truck while at the same time holding the button of a working garage door opener remote
3. Once the Evic says trained, run into your garage and press the learn button on the back of your garage door opener (usually a red button)
4. Now quickly go back to your truck and press the opener button in your truck twice quickly.
It should now work.
Old 07-12-2013, 10:23 AM
Rep:39
To clarify my process, I have the old style dip switch opener - no need to teach it anything.
Old 07-12-2013, 11:46 AM
JaxLoki's Avatar
JaxLoki JaxLoki is offline
Trim Level: Sport Crew 4X4
Color: Deep Cherry Pearl
Rep:14
JaxLoki is on a distinguished road
Closing my truck door solved my issue. Couldn't program it with the door open.
Mufflex DOD14M, BakFlip Fibermax, K&N Drop-in Filter, Stubby Antenna, In-Cabin Air Filter Mod, Painted Tips, Debadged and B-pillar tape removed, Plastidipped All Chrome, Recon 60" Xtreme Light bar, Linex'd Go Rhino Dominator III Steps, 295/70 18 Trail Grapplers, Fuel Throttle 20x9, ReadyLift SST
Old 07-12-2013, 04:07 PM
nikeman nikeman is offline
Rep:91
I had this problem also and started a thread about it. I still have not been able to program mine. Ill try the suggestions here next time I have a chance. Picture me running back and forth from my garage to my truck like a dumb ass about 15 times for no reason!
Old 07-12-2013, 05:11 PM
Scott H Scott H is offline
Vehicle: 2014 Ram 1500
Rep:12
Scott H is on a distinguished road
I had the same problem. Think of it as (STEP 1) programming the truck remote to match your garage door remote per manual instructions, THEN, (STEP 2) programming your garage door opener to accept the trucks remote signal with the learn button on your opener motor (mine was inside the light cover).
Once you've trained the trucks remote(STEP 1) press the learn button on your opener motor till led lights up then get in truck and hold truck remote button down till it works. Both steps seem to require holding the button for a long, long time.
Hope this helps.
Old 07-12-2013, 06:25 PM
Grubrunner's Avatar
Rep:3883
My Apple garage door and its rolling-code would not sync with my truck according to Homelink®
I had to purchase the item below for it to work.
http://www.frys.com/product/5663371
Works great since.
Grub out!
