Old 03-22-2011, 10:46 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
Default *** who ever figures this out is a genius truck wont start***
so i have a 1996 dodge ram 1500 318ci v8 with a 1997 dodge ram 1500 318ci engine no big differance aside from a few different connectors but thats not the problem
heres the problem basicly when i replaced the engine with the one out of the 1997 that had 81k miles on it initially it wouldnt start then all of a sudden it fired up found it kind of weird but what did i care it ran then just recently truck was running fine but i figured id replace the pcv valve spark plugs and do an oil change with synthetic oil and lucas synthetic oil stabilizer but when i was done replacing everything it wouldnt start then all of a sudden again fired right up and ran fine until today for the past 6 hours ive been screwing around testing all sorts of things to figure it out but it just wont start any help or questions would be great the sooner the better cause i need to go to school tomorrow and i cant miss any more or else im getting dropped so like i said the sooner the better cause i gotta figure this out tonight
THINGS TO NOTE: its getting spark and the spark plugs are pre gapped platnium plugs. 2 plugs and wires were not removed due to their location which rules out a bad set of plugs. i put on a brand new ignition coil and nothing changed. its getting fuel it just wont combust not even with starting fluid and there is pressure in the fuel rail.
im thinking the crank shaft positioning sensor but this is my first dodge ive owned
thank you my name is brondon feel free to call me any time 951 427 O831 or email me brondondolon@gmail.com or just post on here which ever is quickest for you
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 03-22-2011, 10:49 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the site
Sorry I can't help ya but hopefully someone on here tonight can. My guess is a lose connection somewhere.
Old 03-22-2011, 11:16 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Wish I could give you an answer, sounds like an odd problem. Drop by the newbie section and introduce yourself.
A big hello and a warm Carolina welcome. I hope you enjoy the best RAM ForumZ.
Old 03-22-2011, 11:42 PM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
did you make sure all of the wires are ran to the correct plugs? never hurts to check it again.
are the plugs correct?
I would try swapping old parts back.
What plugs are you running?
does it turn over?
need more info.
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 03-23-2011, 02:32 AM
Trim Level: 1500
Rep:177
@danny
all the connections are fine i spent all day trying to figure it out and the connections are one thing i went over and over and over again
the plugs are autolite platnium plugs which doesnt really make me think they would be the cause of the problem cause they are all getting spark and there are 2 plugs and wires i didnt even touch so with that said it should at least fire up some what
the truck cranks so the starter is good it just doesnt fire nothing not with anything
but like i said it ran fine and then after i replaced the spark plugs it wouldnt start but then it fired right up ran good and then when i got out of class it just wouldnt fire up
one thing i should add though is it did this before when i first replaced the engine with the new one out of the 97 ram but after that initial time it happened it didnt do it again till now
thank you for all your replies and help i appreciate it
Old 03-23-2011, 02:33 AM
Trim Level: 1500
Rep:177
im thinking either ECU or CPS?
Old 03-23-2011, 07:59 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
i second the thaught on the crank sensor, to me it screams CPS. that is a symptom of one going bad.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-23-2011, 08:12 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
could it possibly be the CAM position sensor? or did those years not have em yet...
i was thinking, Crank PS, Cam PS, ECM, Ignition circuit (like in the column... I've seen it happen where you jiggle the key or cylinder assembly and the truck starts).. hmmmm
good luck tho.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 03-23-2011, 08:23 AM
98redbull2's Avatar
Rep:52
yea all the second gens had em, the cam sensor is unlikely compared to the crank sensor.
Old 03-23-2011, 09:11 AM
Rep:1885
Have you scanned the PCM? Did you check fuel pressure/volume? What about an injector pulse? The CKP sensor could be bad without throwing a code so you either have to check it with a lab scope or blindly throw a new one at it with the hope it fixes it.
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
My truck got hit yesterday. GeauxHunting Dodge Ram General Discussion 41 11-19-2010 01:15 PM
Rumor: sounds like a new SRT truck is coming partypooper Dodge Ram General Discussion 7 11-12-2010 02:08 PM
Dirt Builds Up in the Bed of My Truck Rocky Harbour 2010 Dodge Ram Forum 4 05-27-2010 12:23 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
