Please help identify this set up - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-12-2013, 05:13 PM
Alkire193's Avatar
Alkire193 Alkire193 is offline
Trim Level: 1500 Sport
Color: Blue
Alkire193 is on a distinguished road
Default Please help identify this set up
Hey guys. I was cruising some images and found the ideal wheel and tire setup that I want to use but I am having some trouble identifying what was done to make the wheels fit up so well. Does anyone know this truck's owner or the size of tires, wheels? (third thumbnail from the left)
For me it looks dropped 1-2" with a 35" tire on a 20" wheel. Unknown offset.
Any help would be appreciated!
http://www.google.com/url?sa=i&rct=j...73749847217433
Old 07-12-2013, 05:28 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Your link is not working 100% correct. Are you referring to the black Ram with the bushwacker pocket flares on it?
Also, you can't fit 35's unless you have a leveling kit (lifted at least 2" in the front) so there's no way it's been dropped and running those size tires.
Old 07-12-2013, 05:41 PM
Alkire193's Avatar
Color: Blue
Ok, thanks for the heads up. It is a black 4th gen crew cab with RBP grill and RBP wheels and fender flares . I guess you know the truck pretty well.
Second try:
Old 07-12-2013, 05:47 PM
Moderator
Rep:2140
Yes okay, this is the picture I figured you were referring too.
Definitely has a leveling kit on it, it's not lowered in anyway. The reason it looks like it might be lowered is because of the bushwacker pocket flares.
They're 20" wheels for sure and probably 35x12.5 tires. In order to be flush with bushwacker pocket flares you'd need a 20x10 -12 offset wheel or if you want to be sticking out 0.5" inch you'll need 20x10 -24 offset wheels. The ones on the picture look to be 20x10 -12 offset to me.
Old 07-12-2013, 05:54 PM
Alkire193's Avatar
Color: Blue
Thank you! This is why I love coming here. Wheel/ tire combos are a PITA.
Now I'll do some research on leveling kits...
Old 07-12-2013, 06:23 PM
Moderator
Rep:2140
No problem.
For leveling kits I definitely recommend the Bilsteins 5100 Adjustable's. They are the best way to level a Ram IMO. They have 5 different height settings, 0", 0.7", 1.4", 2.1" and 2.8". Most guys run them at either 2.1" or 2.8" for leveling. You're probably looking at around $220-ish for the Bilsteins plus a couple hours of install.
If you're on a bit of a tighter budget then I'd check out Hell Bent Steel. They make 2.5" leveling spacers for $80. Can't really go wrong with that.
If you need any pricing on wheels, tires, Bilsteins, or any other aftermarket part contact Andrew or Jeremiah at Bully's Performance. They're a site vendor for Ramforumz and will get you some really good pricing on anything you need. Plus they're really good guys to work with and provide great customer service.
andrew@bullysperformance.com or fastNugly @ BP on the forum
sales@bullysperformance.com or jhinkle @ BP on the forum
Be sure the mention that you're a Ramforumz user for discounted pricing.
Old 07-13-2013, 04:32 AM
Alkire193's Avatar
Color: Blue
One stop shopping center! Thanks!
Thank you for this. Never really messed with trucks so it's all new to me, but I'm a solid mechanic so I can figure it out. Adjustable sounds like the way to go, now I just have to pick the wheels and tires.
Old 07-13-2013, 06:50 PM
Moderator
Rep:2140
Ya for sure! Good luck getting it all figured out!
Old 07-17-2013, 05:51 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Rep:1543
Like Brandon said, the Bilsteins are great. They not only bring the height of the truck up but they also upgrade the existing shocks. Glad I went with them. Also, like Brandon said they can be a little spendy. All in for the front two Bilsteins I dropped $450 installed. If I had to do it again I would. They completely change the look/stance of the truck for the better.
Old 07-17-2013, 06:03 PM
Alkire193's Avatar
Color: Blue
Does it make the truckk truly level if I just change the fronts? I have some on order with Bully right now but I dont know if I need rears or not
I also did some coils when I was 17. If you get the spring clamps from Autozone you can do this all yourself in an afternoon. Save money. I would have hooked you up for a case of beer
