a/c goes to top vents..cool/warm with heavy throttle - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-12-2013, 05:34 PM
v8only v8only is offline
Vehicle: 2001 Ram 5.9 4x4
v8only is on a distinguished road
Default a/c goes to top vents..cool/warm with heavy throttle
01 5.9 ram....ac works..but heavy throttle it goes out vents on top of dash...and while driving moderate throttle results in it being not as cool. I was told possible ac vacuum lines..any ideas where to start with this...thx
Old 07-12-2013, 08:21 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
My truck did the same thing, I replaced the vacuum check valves for the HVAC controls.
They go through the firewall right next to where the AC refrigerant (aluminum tube) goes. On the passenger side.
Good luck, and keep us updated with what you find out!
Old 07-23-2013, 01:39 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:57
Wh1t3nukle will become famous soon enough
You possibly have 2 issues going on.
For the case of losing the cooler temps due to engine load, this is typically a result of a vacuum leak. A line has broke, for example. Find them all and check visually. Typical place are the vac lines down near the front axle CAD location. I experienced this a couple months ago.
This may also be the cause of the blowing only through the defroster too. It may be another issue that I'll reserve for later if the above does not resolve.
Good luck
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 06-26-2014, 09:42 PM
Boyd Crowder Boyd Crowder is offline
Vehicle: 1996 RAM 1500 4X4
Boyd Crowder is on a distinguished road
Is there an AC vacuum diagram out there?
Old 07-07-2014, 07:31 AM
912fourtysx 912fourtysx is offline
Vehicle: 98 dodge ram
912fourtysx is on a distinguished road
it is 3 lines total. one comes out of the refrigerant lines and into a t. that runs one into the plastic cowl below the windshield the other line that from the t goes to the engine's intake. i just went through this with mine a week ago.
Old 07-08-2014, 11:06 PM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
Relax. Upon heavy acceleration, or low-vacuum, the system is designed to flow air thru the defroster, and not the vents. The defroster is the "default" position when there is low-vacuum. Like under heavy acceleration, or a vacuum leak. The thinking is that "in the event of a vacuum failure, you will have a clear windshield".
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
