Old 07-12-2013, 07:31 PM
48pege 48pege is offline
Vehicle: 2011 Ram 1500
Color: Rugged Brown Gold trim
Rep:32
48pege is on a distinguished road
Default If it wern't for bad luck....
I took our truck grocery shopping today. Rolled the tonneau cover back to put the cold stuff in the cooler as we live about 45 minutes from the store. As I was about done the wife yells the truck is on fire. I look up and the tonneau cover is smoking like crazy, I unroll it real fast
it quits smoking and has two holes melted in it. I roll it back up to finish loading the cooler and it starts smoking again. Only thing I can figure out is I have an 8 spoke chrome clad wheel that matches the rest of the wheels on my truck for a spare in the truck bed and the sun reflecting off it like a magnifying glass melted the holes in the cover. Going to need a new cover.
Harvey
Old 07-12-2013, 07:49 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
WOW! That really does suck. Sorry to hear that, Dood.
Sounds like it's time to put some Plasti-Dip on your wheels so they don't burn a whole somewhere else.
Old 07-12-2013, 08:29 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Wow. That's crazy! I can believe it, though.
Old 07-12-2013, 09:56 PM
Rep:32
First thing I did when I got home was throw a rug over that spare so it wouldn't happen again.
Harvey
Old 07-12-2013, 10:00 PM
Asur Asur is offline
Vehicle: .
Rep:4373
that's weird, seriously need to check this and do some tests, my spare is under my bed, where is yours located?
Old 07-12-2013, 10:17 PM
Vehicle: no car
Rep:3238
He mentioned his was in the bed. Judging by the way my chrome wheels reflect the sun while mounted on the truck, I can only imagine the reflectivity it would have lying horizontal in his bed!
Old 07-13-2013, 12:53 AM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
wow, wonder if this could start a fire in dry grass or leaves.
Old 07-13-2013, 01:19 AM
Rep:2968
Probably not. The ignition temperature for dry grass in low humidity is over 400 degrees (f) 204 degrees (C) for you crazy canucks. The reflection from the wheel was probably no more than 200 (F) 93 (C). Enough to cause some melting and smoke from the plastic tonneau cover, but not enough to cause ignition.
Old 07-13-2013, 04:34 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
So what type of tonneau cover do you have that ignites in 10 seconds or less? Sure dont want to buy that one!
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 07-14-2013, 12:00 PM
Rep:32
I have a Truxedo cover on my truck. However I don't that has anything to do with what happened. Since the spare won't fit under the truck I have had it in the bed for over a year and have rolled and unrolled the cover countless times with no problems. As they say this time all the stars had to be in perfect alignment for it to happen. The sun had to be at the right angle, the cover at the right spot over spare and dumba$$ me putting the cover back in the same place the second time.
Harvey
