Spacers and rubbing question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 07-13-2013, 02:07 AM
Cornhusker's Avatar
Cornhusker Cornhusker is offline
Vehicle: 2012 1500 Ram Big Horn
Color: Dark Slate/Medium Graystone
Cornhusker is on a distinguished road
Exclamation Spacers and rubbing question
I have a 2012 ram 1500 4x4 w/ 6" bds lift and 37" x 12.5 tires. I want was thinking about getting wheel spacers to flush my tires with my bw pocket fender flares. Has anyone done this? How far can I go out without rubbing/ mild rubbing?
1500 Big Horn 4X4- 6in BDS lift.37in Nitto Trail Grapplers on 20X9 ProComp Chrm
Old 07-13-2013, 06:54 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
What wheels do you have on it now? Stock or aftermarket? Specs?
Old 07-14-2013, 01:05 AM
Cornhusker's Avatar
Procomp
20x9 wheel size
5x5.5 bolt pattern
0mm offset
5" backspacing
Old 07-14-2013, 02:02 AM
Moderator
Rep:2140
So I'm assuming you're sticking out about 1.5" past the fender line. Bushwacker pocket flares extend 2.5" so you will need a 1" spacer to sit flush or a 1.5" spacer to stick out a half inch (which is what would look better IMO). You should be able to do that with your 6" lift no problem... If there is any rubbing it would be at the back of the inner fender liner or the front plastic valance. Both can be easily fixed with a bit of trimming.
Old 10-10-2013, 08:26 PM
burtonxrider21's Avatar
burtonxrider21 burtonxrider21 is offline
Vehicle: 2012 dodge ram 1500 sport
Rep:92
burtonxrider21 will become famous soon enough
I have a similar question... I just bought a set of 325/60/20 Goodyear Duratracs to run in the winter on my stock 20x9 rims. I was wondering what size of spacer I would need to bring them out flush or a little past my Bushwacker pocket flares... The whole backspacing/offset thing messes me up for some reason! I know that with the stock rims and tires they were flush with the fenders.
Old 10-10-2013, 08:41 PM
Moderator
Rep:2140
You'll need 1" or 1.5" spacers to be fairly flush with your pocket flares. 1" will be slightly tucked under while 1.5" will be slightly past.
Old 10-10-2013, 09:05 PM
Rep:92
Right on, thanks! I want to order them so that they arrive before the snow flies!
