ABS ECU Wiring Color Help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-13-2013, 01:44 PM
StevieB StevieB is offline
Vehicle: 2004 Dodge Ram 2500
Trim Level: SLT Heavy Duty
Color: Maroon
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
StevieB is on a distinguished road
Smile ABS ECU Wiring Color Help
Hi. I posted about 5 weeks ago about an electrical fire with the connectors from the harness to the ABS ECU Controller I had under the hood. I've since sourced a 14 pin and a 4 pin connector each has a foot of wire to connect to the harness and an ABS ECU Controller. The problem I have is all the wires are the same color from the new connectors, which wires do I connect to the harness as the fire has burnt more than half. Could someone please advise from their own vehicle which color wire leads to each of separate 14 pins e.g. yellow & green go to 1, blue & white go to 2 etc. all the way to 14. The same for the 4 pin connector. A picture would also be very helpful. Not many similar pickups here in England hence the call for help to the USA. Thank you.
Old 07-18-2013, 05:18 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Bump... I don't have ABS or a Cummins. But I do want to bump this so another member might be able to pick it up and help.
Old 07-18-2013, 06:09 PM
HemiLonestar's Avatar
Rep:289
Hit download button
http://www.mediafire.com/view/8k5u7y...ice_Manual.pdf
Wiring schematics inside
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
