Old 07-13-2013, 05:18 PM
nikeman nikeman is offline
Rep:91
Default Anyone install bed lights in their 13
I noticed the mopar light instructions only say for up to 2012 models. I want to tap into my cargo light wire but I do not want to mess up the warranty or the computers or what ever else I could do by tapping into that wire.
Old 07-14-2013, 12:12 AM
Lobo Lobo is offline
Vehicle: 2013 Ram
Color: Grey
Rep:14
Lobo is on a distinguished road
May work but with the things I've read about happening when messing with these truck's wiring, I'd be really sure before I tried jumping any wires.
My dealer didn't want to wire a light in my cover even when I asked about just running separate wires directly to the battery with an inline fuse.
I've decided to use battery operated LED lights with a wireless remote and velcro them underneath my cover.
Old 07-14-2013, 12:38 AM
Rep:91
That's what I was afraid of. Maybe I can find a spot to mount a switch close to the tailgate or something. I think I'll ask the service guy when I bring the truck in for the new ECM.
Old 07-14-2013, 12:45 AM
bstunder bstunder is offline
Vehicle: 2013 Ram 1500 Laramie Longhorm
Trim Level: Laramie Longhorn
Color: Grey Met
bstunder is on a distinguished road
Or just pull power from the 7-pin trailer plug at bumper.
Old 07-14-2013, 12:49 AM
Rep:91
That was my plan if I used a switch, but I just can't find a good place to mount a switch where its out of the way but easy to access. Do any of the 7 pin wires have constant 12v even when the truck is off?
Old 07-14-2013, 03:46 AM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1543
Is this what you were thinking of?
http://www.amazon.com/TruXedo-170499...ery+bed+lights
I was thinking of doing the wired ones but you bring up a good point about the truck's electronics. These may be the only way to go.
Magnaflow 14" Custom Install Bilstein 5100s Front Only Set at 2.8" Vararam Air Grabber Cravenspeed Stubby Antenna Dee Zee Tailgate Assist Billet Technology "The Punisher" Shift Knob Debadged doors and tailgate Plasti Dipped HEMI Badge The Punisher Grille and Tailgate Badges Exterior Chrome Delete 20" XD Series 795 Hoss LT305/55R20 Nitto Trail Grappler M/T Cabin Air Filter BAKFlip Roll-X Tonneau Cover
Old 07-14-2013, 07:30 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
All you need is to install a relay and a fused wire to the battery and lights. This is triggered by taping into the cargo light wire and it will not over draw power from the trucks OEM wiring. You could run some heavy powered driving lights with this setup or just some LED strip lights. Use the proper rated wire and fuse for what you are going to install as far as wattage needed.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 07-14-2013, 11:26 AM
CowboyZ51's Avatar
CowboyZ51 CowboyZ51 is offline
Vehicle: 2013 Dodge Ram Sport
Rep:19
CowboyZ51 is on a distinguished road
i bought the LED Glow ones, just haven't had time to install yet, but it shouldn't be a problem in you use the relay setup and tap into the cargo light as gcscott suggests.
hoping to get a bit of truck time this weekend, ill update after i have them installed.
Old 07-14-2013, 11:28 AM
rb10475's Avatar
rb10475 rb10475 is offline
Vehicle: 2013 RAM 1500
Rep:33
rb10475 is on a distinguished road
I plan on using a LED set that is at autozone. They were only $25 and all that needs done is replacing the test button on the packaging with a toggle. Id rather replace a battery one in a while instead of giving the dealer a reason to not fix all the problems with our electronics.
Truxedo TonneauTrax & K&N Drop In & Bilstein 5100s
Old 07-14-2013, 12:38 PM
kxlexus kxlexus is offline
Vehicle: 2013 Laramie 4X4 Quad Cab
Trim Level: Laramie Hemi 8 Speed
Color: Maximum Steel Met.
Rep:25
kxlexus is on a distinguished road
That sounds like an excellent idea. Do you have a link to your setup?
