Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
tonneaucovered.com
Old 07-13-2013, 07:48 PM
Cluster F Cluster F is offline
Vehicle: 2007 ram
Trim Level: LE
Cluster F is on a distinguished road
Default Radiator/coolant problem/ AC
i have a 2007 ram Hemi 1500. I was noticing i would have coolant all over the hood of my truck randomly. I found out i had a pinhole leak at the top of my radiator. I did not have the money to replace it so i let it go for a bit. I would burn off coolant. i could smell it at idle or after i drove walking around my hood . the overflow tank would always be way low and the radiator would be low. i have never had a problem with it overheating though. My question is, is it just in need of new radiator and a flush or something else? kinda nervous about horror stories about head gaskets and stuff but i dont see anything wrong with the oil or leaking anywhere else. i am pretty sure im just smelling the coolant burning off from the hole. when i got my oil changed the guy didnt know i had a leak but saw i was pretty low and said he though it was holding to much pressure or somewthing.
Side note haha. My AC is not cold. not sure if i have a leak or its just low on coolant and can do a recharge. when i run it when its hot out i get a ton of water dripping on the ground i know this is normal when it actually runs colt but it never does.
Old 07-14-2013, 01:20 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Yes, you need a new radiator. Don't spend the time or money trying to mickey mouse it. Just get a new one installed.
As far as your A/C not blowing cold, sounds like the condenser is condensing, but your not getting any cold air. I'd have a qualified A/C shop check it out 1) for pressure and 2) for a bad expansion valve. It may be clogged which would cause high pressure but no cold air.
Old 07-25-2013, 09:34 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
save yourself the trouble do not put in stop leak, it's the worse thing ever for a coolant system. I am having to flush the block and replace everything in my cooling system because the prior owner used and continued to used stop leak. I am going to assume he never changed the coolant and ran mostly water after a point with it leaking and him topping it off...
This is the results of his mechanical expertise. This crud is caked to everything, hoses, heater core, radiator. I can't imagine how clogged my radiator is.
