Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 07-14-2013, 12:15 PM
sobx1 sobx1 is offline
Vehicle: 2005 ram 3500 cummins
Color: red
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
sobx1 is on a distinguished road
Default 05 ram 3500 electrical issues
I have lots of trouble with the rear light pc board. Replaced them several times. It appears that the pc board leaks water inside and causes rust and corrosion and failure. Now my power windows are failing due to wire breakage at the hinge point of the doors. Short of buying an entire new wire harness (dodge dealer) what are my options and has anyone else experienced this trouble?
Old 07-14-2013, 01:56 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I have heard of it, but not experienced it. Probable cause is the harness was pulled too tight. Easiest fix would be to splice the broken wires leaving some slack in them so it doesn't happen again.
