Don't go get all excited nothing major. I got some 68 smd LED and changed out my backup lights.
This will also be my first attempt at a write up but I am sure others have already done it.
Time Required: 5 minutes
Tools: Torx #25
2 LED 921 Bulbs
Pretty simple. Drop tailgate and remove the 2 screws holding in the taillight
You will need to pull a bit to get the light housing to release but there is lots of cable so no worries about pulling it out.
Here is the back of the light turn the base and the light will come out.
Remove old bulb and insert new LED. Now to put it back together. You need to line up the 2 silver nipples that are ont he right side of the picture
With the 2 black clips. They are a pressure fit so you just need to push them in
Then put the screws in and your done. I don't th ink I have forgotten anything. Like I said it is simple and quick as it took me longer to do this post then to install the lights.. Will try and get some pictures of the lights when it is darker. The only other mod I know of on my truck are the headlights here are some pics of them
They were done when I bought the truck
Tools: Torx #25
2 LED 921 Bulbs
