Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-14-2013, 03:49 PM
MEZERR MEZERR is offline
Vehicle: 2012 Ram HEMI
Rep:36
MEZERR is on a distinguished road
Default My air conditioning is breathing heavy
2012 RAM. 5.7L. 10,000 miles
When driving (doesn't do it when idling), and with the AC on. Every 10-15 seconds, there's something breathing behind the glove box. It sounds like my dog is breathing heavily when sleeping. Take a deep breath through your noise, everytime you breath in, and that's the sound I"m hearing.
Havn't brought it to dealer yet, as everytime I bring something in, they say "That's normal, and performing as intended"
Ideas?
Old 07-16-2013, 01:53 AM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Not sure have you owned since new? Mine was quite till I did the air box mod. To add a cabin filter not it make some noise. Sometime is whistles at me. But that I think it is normal.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 07-16-2013, 09:41 AM
Kaiser Kaiser is offline
Vehicle: 2011 Ram 1500
Kaiser is on a distinguished road
Sounds like its the recirc door opening and closing. I know I have heard mine do it a few times but not as often as yours. May want to to have your dealer check it out.
Old 07-17-2013, 12:30 PM
Rep:36
Ugh. I sent a detailed summary of the noise to one of the dealers here. He called back and said it's probably normal. He thinks it's the A/C cycling on and off. He said it's a sign that the system is working. I said the A/C is supposed to cycle on and off every 10 seconds? for hours? He said yes.
UGH. Why won't dealers even look at their trucks anymore? Why do I always have to prove there's a possible issue, instead of the dealers investigating themselves.
So, nobody hears a deep breathing behind the glove box, with the AC on? It doens't do it when idling, but only when the engine is revving 1800 RPM's and higher
Old 07-17-2013, 12:53 PM
Do you have it on just the vents in manual mode or on auto? If you do try setting it to the floor or mix mode or even defrost but make sure and keep the A/C on and see if it still does it. In these modes it should not go into recirc mode so it will tell you if thats making the noise.
Old 07-17-2013, 01:57 PM
Rep:36
Tested another scenarios. I turned the A/C off, and turned the defrost on. I could hear the breathing noise still. But with the A/C off, and the vents on, no breathing noise.
So the noise happens when A/C is on, or defrost, and only above 1800 RPMS
Old 07-17-2013, 09:03 PM
maine7777's Avatar
maine7777 maine7777 is offline
Vehicle: 2012 Ram 1500 QC ST
maine7777 is on a distinguished road
Default trouble shooting suggestion
The recirculation door is directly behind the glove boxes. By removing them you will be able to see it moving by turning the recirculation on and off. Get it to the open position and check to see if there is are foreign objects in or over the intake grate that is visible with the recirculation door open. I would also make sure that you are getting a good seal when the door is closed as this is the position that I think it is in when on defrost (no recirculation).
Old 07-18-2013, 02:00 PM
Rep:36
So, by turning recirculation on and off, I can hear the door moving. It's very quiet. But it's NOT the breathing noise I'm hearing.
I'm pretty sure I hear the expansion valve opening or closing. The problem is, it's happening every 7 seconds, and lasts for 10 seconds or so. The air in the truck has never been FREEZING, but I would say it's almost cool. I'm not sure how cold it's supposed to get. It is 100 F outside
Old 07-18-2013, 05:29 PM
Rep:36
One other thing I noticed... at the same time I'm hearing this hissing noise, I can hear the ac compressor kick in. So my AC compressor is starting, stopping, starting, stopping ever 10 seconds........
Old 07-19-2013, 09:20 AM
Rep:36
Now my compressor is on 6 seconds, off 6 seconds, on 6 seconds, off 6 seconds. And it's now making a garggling noise.
Goes into dealer tonight, I guarantee you they will say "Well, it's probably because it's hot out"
