Towing mileage - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
Diesel Forums!
Dodge Caliber
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 07-14-2013, 03:26 PM
triker08 triker08 is offline
Vehicle: 2009 Dodge Ram 1500
Color: red
triker08 is on a distinguished road
Default Towing mileage
I have a 2009 Ram 1500 crew cab, short bed, Laramie, with 5.7 engine. I am thinking about buying a 5600lb toyhauler to pull. We will be putting a 1100 lb trike in the unit. What can I expect for MPG?
Old 07-14-2013, 03:39 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
I tow 3000 lb bass boat for 20 miles at 70mph one way and get 13mpg hand calculated. I'd almost bet you could get 11-14mpg depending on your speeds.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 07-14-2013, 04:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I wouldn't expect more than 10-12 at 65-70mph.
Sean
Old 07-14-2013, 05:45 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
This is a realistic expectation., but will have to factor in the terrain you will tend to travel on as well. What will affect your MPG negatively the most is not the weight, but the aerodynamic drag of the trailer.
Old 07-14-2013, 06:19 PM
Outdoorsman2012 Outdoorsman2012 is offline
Vehicle: 2012 Ram Outdoorsman
Trim Level: Oudoorsman
Rep:39
Outdoorsman2012 is on a distinguished road
I think all the above estimates are very optimistic. In reality you will get more like 8-10. My camper is 7420lbs I know it weighs a little more but a toy hauler usually gets taller in the rear and has may have more wind resistance than a tt. Mine is also a full height tt so i'm 11'4" w/ ac. Once i break 60mph my mileage drops a lot as the truck will downshift more often. When I stick to 60mph downs shifts occur less often and have to usually be a moderate sized hill. 55mph is almost too slow as the rpms are a little lower so it can't hold the speed. Also as you probably know tires for tt are rated only for 65mph.
Old 07-14-2013, 06:38 PM
Ezekielguy86 Ezekielguy86 is offline
Vehicle: 2012 Dodge Ram 1500 5.7 HEMI
Trim Level: ST Express
Rep:71
Ezekielguy86 will become famous soon enough
I tow a travel trailer for work from time to time anywhere from 4500lb to 6500lb so far and have always got 11-12mpg.Thats with 3.92 gears.
Diablo Sport Intune HemiFever 93, S&B Intake, 14" Jones Full Boar, Mag Y Pipe, 180 T-Stat, Billet Catch Can, Pioneer 5500BHS, Fox Box W/ Type R, Air Lift 1000
