Whining noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-14-2013, 07:40 PM
2step 2step is offline
Vehicle: 09 ram
2step is on a distinguished road
Default Whining noise
Sounds like a power steering pump out of fluid, everything look fine more you rev the engine the more you hear it. Anyone else have this problem on 09 ram sport, with hemi.
Thanks
Old 07-15-2013, 06:32 AM
BULLRAM's Avatar
BULLRAM BULLRAM is offline
Vehicle: 2009 Dodge Ram 2WD
Trim Level: slt- lonestar
Rep:61
BULLRAM will become famous soon enough
yes , it was the idler pulley . it costs about 11.00$ ---15.00$-- at Napa, and is super easy to change out, I have replaced 4 on some friends trucks so far.
It is not the tensioner pulley, it is the idler pulley..you dont have to pull off the belt, if a friend holds the tension off of the belt with a tool, you can remove the bolt and swap it out.
Old 07-21-2013, 08:29 PM
Big Guy Big Guy is offline
Vehicle: 1999 Dodge Ram 1500 2WD
Trim Level: Laramie SLT
Big Guy is on a distinguished road
My 09 5.9 makes a whine in reverse which increases with engine speed. Think it could also be the idler pulley?
Also...a clunking sound comes from the rear body when the truck is torqued as when turning into an uneven driveway at slow speed. I changed the shocks and installed a tailgate hinge kit and it's better but not completely eliminated.
Any ideas?
Thanks
Old 07-24-2013, 12:33 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:801
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
big guy, do you have lsd?
Old 07-24-2013, 11:00 PM
Default clunking in rear of truck...
Yes, could you elaborate please? I also hear the noise when driving slowly such as in a driveway...and frequently while turning corners at slow speed on city streets. It can't be good. It sounds just like the exhaust system is moving and hitting something but that appears to be solid and moves only when the hangers allow it some leeway.
Old 07-24-2013, 11:20 PM
constableal constableal is offline
Rep:19
constableal is on a distinguished road
LSD....Limited Slip Differential
