Does a dirty IAT sensor affect A/F - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 07-14-2013, 10:58 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Default Does a dirty IAT sensor affect A/F
Hello all well I finally figured out why my truck was surging after the new cam install. After checking everything I finally checked the IAT and it was black on one side. So I removed it and cleaned it now the surging has completely gone away. My question is will a dirty IAT sensor effect my A/F. Im wondering if this sensor is what caused my truck to run really rich on idle and lean out at WOT while on the dyno a few weeks ago or is there something else? Thanks
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 07-17-2013, 11:40 AM
usmcz28 usmcz28 is offline
Trim Level: 1500
Color: Blue
usmcz28 is on a distinguished road
If the IAT is not reading the proper inlet temps it will either reduce or increase timing and can affect A/F through that. Your A/F is generally dictated by your O2 sensors and their voltage reference to the PCM
Old 07-17-2013, 04:40 PM
guru1ofatl's Avatar
guru1ofatl guru1ofatl is offline
Rep:22
guru1ofatl is on a distinguished road
Most engines go into open loop at WOT so the O2 sensors aren't being used. This is why tuning is needed otherwise the ECU would just use O2 readings to adjust the mixture for whatever mods are installed.
MAP, CTS, and IAT are the biggies at WOT.
