Old 07-15-2013, 12:03 AM
logan1080 logan1080 is offline
Vehicle: 2013 ram 1500
Trim Level: sport
Color: maximum steel blue
logan1080 is on a distinguished road
Default Truck fails to start, warning lights....
2013 ram 1500 with hemi, 800 miles on the clock. The truck has failed to start when I hit the start button 3 times now. It has had several rough starts, fires right away but stutters or a subtle knock. No engine codes, no DLC's with engine scanner. However I noticed in the screen between odo and spedo two lights flash back and forth, the engine temp warning light which is red and another symbol not in the manual: a steering wheel with a "!" beside it, this is also a red light. No idea what this light means. The engine temp light makes no sense because it comes on even before the engine is warmed up. Anyone know what the other symbol means? I'm going to the dealer but I'd still like to know what the mystery light is.
Old 07-15-2013, 06:59 AM
maw76's Avatar
maw76 maw76 is offline
Vehicle: 2013 RAM 1500 QC
Trim Level: Outdoorsman
Rep:49
maw76 is on a distinguished road
the steering wheel light is cause our steering system is electric, it flashes like oil, engine light at start up cause it is verifying the system that all sensors and connections are good. If it stays flashing after the fact that the engine is started then you have a problem.
