Old 07-15-2013, 05:42 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
There are times when I drive a few miles, whether it be through mcdonalds or just stopping at a red light, that when I accelerate again the fan is loud for a few thousand feet up to a mile from beginning acceleration.
Likely it is just that when sitting idle in the drive through the temperature gets hot enough for the thermostatic spring on the clutch fan to allow the fan to engage. Then once driving down the road you have airflow through the radiator, engine bay, etc. and the temp cools down a little and the clutch fan disengages again.
Sean
Old 07-15-2013, 05:45 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Originally Posted by JE13BigHorn View Post
Gantman, That makes sense. So would you be concerned that it does it even after operating for a while. There are times when I drive a few miles, whether it be through mcdonalds or just stopping at a red light, that when I accelerate again the fan is loud for a few thousand feet up to a mile from beginning acceleration. That is what bothered me... That and the fact that the fan is extremely loud. I'm probably going to take it in to the dealer to have it checked, but I didn't want to end up in there and having not done any research to help explain my situation. I appreciate your explanation. It does definitley make sense.
Yes I would still bring it in to have your service department test drive it to try and duplicate your findings. Not every brand new part is always perfect. You may just have a defective fan clutch that had problems during manufacturing. For example, faulty thermal spring or silicone drive fluid. I remember replacing my fan clutch on my ole 96 Dakota with a 5.9Magnum and I decided to install an aftermarket HD fan clutch to replace my bad OE standard and yes you guessed it, much much louder when engaged. Hey good luck with your Service visit and keep us up on their findings with your truck.
Old 07-15-2013, 06:19 PM
JE13BigHorn JE13BigHorn is offline
Vehicle: 2013 Ram 1500 BigHorn
JE13BigHorn is on a distinguished road
Will do. Thanks for the input.
Old 07-15-2013, 06:27 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I'm thinking the loudness you're hearing is the fan pulling more air as it gets more torque from the clutch engaging. Once the temp goes down, and the fluid drains, slowly disengaging the clutch, the fan looses torque and doesn't pull as much air so it quiets down.
Old 07-15-2013, 11:35 PM
Red6speed Red6speed is offline
Vehicle: 2013 1500 ram
Red6speed is on a distinguished road
My wife and I noticed the same thing twice at weird times when leaving from a stop. We both looked at each other and thought it was the tranny then like you say soon after it goes away. That's when I wrote it off as the clutch fan. It was just kinda loud. Louder than it seems that it should be and the fact it only happened twice in 2000 miles too. I'm in Cali and its been 100+ almost the whole time I've owned it.
Cheers!
Old 07-16-2013, 08:46 AM
Red, that's it. Just seems to be a little louder than it should be. I guess maybe something I'll have to get used to. I'll stop by the dealership sometime this week and just let them double check. Thanks everyone for the input.
Old 07-16-2013, 09:05 AM
Killroy720 Killroy720 is offline
Vehicle: 2013 Dodge Ram 1500
Killroy720 is on a distinguished road
I've done some searching and can't really get a definitive answer to my question. My Ram has 3500 miles on it... Hemi motor... my clutch fan is extremely loud at times. There doesn't seem to be any rhyme or reason for when it happens. It has happened in the morning when first cranking up. It has also happened after driving 5 miles then going through a drive thru and when I leave the drive thru it gets really loud for a half mile or so. It also happens at times in the afternoon when I leave work. At that time it's 90 degrees and it stays loud for the same amount of time as it does in the mornings after setting all night. I'm wondering if the clutch fan may be bad or if this is normal on the '13's?
I noticed the same thing with mine, I took it to the dealership and they replaced the clutch fan
Old 07-16-2013, 12:18 PM
Let me ask this as a general question. Not saying it's right, wrong, bad, or good, but is the Ram known to be something like three times louder than other brands?
