Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Place your Ad Here!
Old 07-15-2013, 01:43 PM
dschutz1979 dschutz1979 is offline
Vehicle: 1987 dodge d150
Trim Level: le 150
Color: red and white
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
dschutz1979 is on a distinguished road
Default starter problems
had starter tested and it was good. when its on the truck all its does is tick. sounds like the gear tries to engage but wont turn over engine. any ideas?
Old 07-15-2013, 09:13 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
sounds like the starter motor is not getting the power needed? have you check your ground connection and cleaned your battery terminals?
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 07-15-2013, 10:15 PM
Trim Level: le 150
the terminals are clean. i noticed the ground would spark some times. ill have to check and how good the connection is.
Old 07-16-2013, 09:44 AM
Trim Level: le 150
thanks for the help crazzywolk you were right. where the battery grounds to the engine was loose. tightened it down the engine turns over pretty fast now. i guess its been loose ever since i got the truck because it would always turnover slow.
