Old 07-15-2013, 05:12 PM
Yumdinger's Avatar
Yumdinger Yumdinger is offline
Vehicle: 2013 Ram
Color: Black Gold Pearl
Yumdinger is on a distinguished road
Default Holes through bed at weld spots
Hey all
First time Ram owner, 2013 big Horn pretty loaded up. Previously owned Ford and Chev. I ordered the Bakflip F1 and bedrug. As I was preparing to install the bedrug and I noticed light shining through my bed along each side at the seam where the wheel well panel meets the flat center panel of the bed. The "void or holes" were right near the weld marks towards the front and rear of the bed, 4 spots in total.
My last Dodge was a Durango, I told people I bought a 200,000 motor and drive train with a 50,000 mile body. It rusted out completely in 5 years.
As a result of that experience I am being particularly careful ( wife would call it ANAL) with this Ram. I love the truck and want to do what I can to preserve it.
Are these holes normal? I live in Minnesota, lots of rain and snow. With the bedrug I do not want a lot of moisture inside. I bought the best hard cover I could to go the extra mile in my efforts.
Any info would be appreciated.
Old 07-15-2013, 05:22 PM
tev9999 tev9999 is offline
Trim Level: Outdoorsman
Color: Maximum Steel
Rep:39
tev9999 is on a distinguished road
I'm having a hard time picturing where you are talking about - pictures would help. There are holes and slots intentionally in the bed to allow for water drainage. The Bed Rug is designed to allow water to flow through the zippers and then out those holes.
Old 07-15-2013, 05:36 PM
Yumdinger's Avatar
Vehicle: 2013 Ram
The seam runs from front to back of the bed full length. It appears the center flat portion of the bed, about 44-46" wide is one panel. It is welded to a panel on the left and the right side of the truck that includes the wheel wells. It is the same on both side of the bed. In this seam about 6-10" forward of the tailgate and about6-10" back from the front wall of the bed are weld marks on each panel. In the seam there are 2 small slots that you can see the ground through. they are about 1/4" long and about 1/6" wide (the width of the seam).
I don't have the truck now but I will try to get pictures later.
Old 07-15-2013, 06:22 PM
UpToNoGood's Avatar
UpToNoGood UpToNoGood is offline
Vehicle: 2014 Ram EcoDiesel
Trim Level: Laramie Longhorn
Rep:61
UpToNoGood will become famous soon enough
My truck and all the others are like that.
2014 1500 Laramie Longhorn CC 4x4 8spd, 3.92 EcoDiesel - Hammerhead rear bumper sprayed with Linex - Iron Cross steps sprayed with Linex - Trucks cover tool box/Tonneau Cover combo - Geno's cabin filter - 275-65-20 Nitto Terra Grappler - Air Lift 1000
Old 07-15-2013, 06:32 PM
zj4x4 zj4x4 is offline
zj4x4 is on a distinguished road
I'd invest in a spray-on liner if you are worried about moisture. I have a Line-x liner and a Bakflip Fibermax. You are going to get a very small amount moisture in the bed even with a Bakflip. Your rug will stay pretty dry but from what I can tell so far after a couple weeks with an unusual amount of rain in Denver the moisture will be in the same place every time. Even in a heavy downpour it's very minimal but I'm curious to see what happens with a big snow melt.
Old 07-15-2013, 06:48 PM
Rep:2620
Look at your Warranty paperwork
I believe that Ram trucks have a 5 year corrosion warranty,
this is from 2010
look at page 9
https://www.dodge.com/crossbrand/war...0%20072210.pdf
Old 07-15-2013, 07:00 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
sounds like drain holes to me
