Old 07-15-2013, 09:05 PM
GJTyler GJTyler is offline
Vehicle: 2004 dodge ram quad cab
Color: Grey
GJTyler is on a distinguished road
Default Bed Liner
I just bought an 04 that has the factory plastic bed liner in it. I heard some crunching when i first walked on it like there were acorns underneath it. I read somewhere that those liners are rust factories. Should I take it off? It also has bushwhacker bed caps.
Old 07-15-2013, 11:13 PM
huntergreen huntergreen is online now
Trim Level: sport
Color: green
Rep:643
you might want to take it off and see whats under there.
Old 07-16-2013, 03:29 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
If it were me, yes I would take it off, clean the bed out and inspect the paint (likely to be scratched to bare metal in spots) and either have it repainted or have a spray in bed liner done. If you like the idea of a spray in bed liner then that will take care of it. If you prefer to leave it naked or install a Bed Rug, then re-painting first would be worthwhile unless you are lucky enough to get away unscathed.
Old 07-16-2013, 04:03 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
I've got the plastic lining. Is it really that bad?
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 07-16-2013, 10:17 PM
Vehicle: A Truck
Rep:2549
The problem with plastic linings is twofold, they do not seal out moisture so moisture gets trapped between the liner and the bed. Secondly, they tend to shift and move around which scratches the paint, typically to bare metal. Compound the trapped moisture and bare metal and rust usually follows. I had one on my first truck back in the 80's and I had to remove the liner for another reason and was appalled at what the liner did to the bed.
Old 07-16-2013, 10:20 PM
Grubrunner's Avatar
Rep:3883
I've never had an issue with a drop-in plastic bed liner.
Grub out!
Old 07-16-2013, 10:33 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3248
PaulMys has disabled reputation
Ditto on my '90 Dakota. There were rust "pin holes" straight through the bed when I removed mine.
Old 07-16-2013, 11:16 PM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
I have always had plastic liners and never had a problem.
Old 07-16-2013, 11:40 PM
Jan 20. Sad Day
Vehicle: no car
Rep:3248
This might be an issue of use. If you baby your bed with a plastic liner, it might never become a problem. The man who owned my Dakota before me with a drop-in regularly abused the bed with heavy loads like cement, sand bags etc. (guess he was a mason as that is what I found under the bed) But it was definitively scarred and rusted through after 3 years.
Old 07-16-2013, 11:53 PM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
A friend of mine had a plastic liner and he didn't do anything with his truck, more than the occasional weekend honey do list and his bed rusted through.
I guess it depends on how well the fit is. If the fit is poor and there is lots of rubbing and moisture (as suggested above) then yep for certain it will be a problem.
I have only ever had the spray in liner and it's great. Of course I've also only had my truck a little over a month, but it just seems the right way to go.
I had it come with the truck so I don't know the cost, but I'm under the impression that it's around $500.00?
If so, then that's money well spent.
