Old 07-15-2013, 09:07 PM
612denise's Avatar
612denise 612denise is offline
Vehicle: 2000 Dodge Ram 3500
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
612denise is on a distinguished road
Default 2000 dodge ram 3500 electrical problem .... radio,interior lights and mirror's won't work
A newbie needs help ... Electrical Problem!!! I give up. I detailed my 2000 Dodge Ram 3500 and now my radio, interior lights and mirrors don't work. Someone told me that maybe I grounded some wires when I moved the seats but I don't know where to start looking. The fuse for the radio is good and the cigar lighter still works. Help!
Old 07-18-2013, 04:59 PM
RogerRamJet's Avatar
Vehicle: 2005 RAM 1500
Trim Level: LoneStar QC
Rep:2933
Define "moved the seats". Did you physically remove them from the cab? Did you spray water in to your engine compartment and/or directly on the fuse box? I would start by going back to everything you touched and inspect it for loose or broken wires. It's sounds like something really simple, it's just a matter of finding it.
Old 08-22-2013, 11:54 AM
wfoltz wfoltz is offline
Trim Level: Laramie SLT
Color: Dark Greeen
wfoltz is on a distinguished road
Default 2000 Dodge Ram Electrical Problems
I have the same problem with my 2000 1500 Ram. The reason for the problem is the CTM Assy. It controls many things such as the mirrors, seats, door locks , lights, and engine disable function just to mention a few. The CTM is located under the dash next to the ash tray just above the gas pedal. It is a black box that is approximately 5"x5"x1 3/4" and has two heavy wiring harnesses connected to it. The CTM had problems with some radio frequencies which would cause it to malfunction. According to the dealer, a new one costs $372.00, so I am looking for a used one. Also, the dealer said that each CTM is specific to your truck (dependent on the truck's equipment) so you need to get the exact SN.
Old 10-01-2013, 02:49 PM
billydj billydj is offline
Vehicle: 1999 Dodge Ram 4x4
Color: Blue
billydj is on a distinguished road
Default Did the CTM fix your problem
The same thing happened to my 99 ram, like you I gace up looking for it after spending 200.00 looking for it, could you let me know if that was it? thanks
