Old 11-10-2014, 05:36 PM
PappenHamster PappenHamster is offline
Vehicle: 2009, 1500 Ram
Color: Yellow
PappenHamster is on a distinguished road
Unhappy engine dies after remote start
i encountered an issue with my remote start.
the engine does fire up after pressing the start button twice. like its supposed to but then after around 5-6 seconds the engine dies.
the board computer says something like malfunction. there also is enough fuel in the tank.
does anyone here know whats going on and/or has got a solution for me ?
im european so im not familiar with trucks or north american vehicles at all !
im grateful for any advice.
thanks in advance
Old 11-10-2014, 11:55 PM
Grimminck11 Grimminck11 is offline
Vehicle: 2009 ram 1500
Grimminck11 is on a distinguished road
It will shut down if not enough gas ( which you said it does) if the hood is popped or I think if a door is ajar, does the dash say anything specific
Old 11-11-2014, 12:58 AM
Color: Yellow
all the computer says is: remote start error. system fault.
door was fully closed. hood was closed. vehicle is locked.
it was fine when i quickly disconnected the battery for a few minutes. but had the same issue the next day
Old 12-12-2014, 10:02 PM
McCraezy McCraezy is offline
Vehicle: 2009 Ram 1500 Sport Quad Cab
Color: Inferno Red Crystal Pearl Coat
McCraezy is on a distinguished road
Do you have a check engine light? it wont auto start if you have any DTCs in the PCM / ECU
Old 12-13-2014, 11:02 AM
comatone1982's Avatar
comatone1982 comatone1982 is offline
Professional meatbag
Trim Level: Sport Crew Cab
Rep:34
comatone1982 is on a distinguished road
Just want to clarify, are you using the factory Ram remote starter, or an aftermarket one? If its the factory installed one, i have no idea. If its an aftermarket one (viper, compustar, etc...) you need to consistently use the remote that came with the kit for ALL functions. In my case, I had to disable passive entry as well. So please clarify if youre using a factory starter or one you bought at futureshop or wherever.
Reflex spray liner // 8% over factory 20% rear tint // Rigid Industries 30" sr lightbar // Weathertech digital cut mats // Billet Industries catch can and engine dress up kit // BFGoodrich All terrain TA/KO 2 tires // Viper remote starter // AntennaX 13" stubby // DeeZee tail gate assist // Mopar SS sill covers
Old 01-05-2015, 10:26 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Check the little pecker under the hood that engages the hood switch. They can come off or partially off misaligning from the switch
"I don't care to hear what your ideas are, mine are better"
Old 01-06-2015, 05:05 PM
hk955 hk955 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn CC SLT
Rep:39
hk955 is on a distinguished road
I have had issues with the check engine light coming on due to the seal on the gas cap wearing out. I can usually clear it by prying the seal up with a key where it is split in the middle of the seal. I think from time it is flattening out and I just haven't gotten around to replacing the seal. Once pryed up, the light will clear and the remote start (factory installed) operates fine.
[FONT="Times New Roman"][/FONT]
The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!
Eleanor Roosevelt, First Lady of the United States, 1945
Old 01-21-2015, 07:55 PM
wr986's Avatar
wr986 wr986 is offline
wr986 is on a distinguished road
Default Had this problem
Hello,
I had this issue early this winter. I drove 4 hours from home to hunt and mine did the same thing. Ran a minute or 2 and stopped. Then all kinds of weird lights and indicators. The temp gauge even showed overheating then a second later it was fine. Long story short, called my service manager in a panic from the middle of nowhere. ........ Issue is a weak battery drives these trucks nuts. I had the original battery from 09 in it. Put in a new interstate battery, cleared the codes and bang its back in action. Somewhere during all the trouble it blew a temp sending unit too but the root of mine was a weak battery. My dealer said the remote start is where a weak battery first shows itself then the rest becomes a domino effect since its being robed of sufficient power..... anyhow mines back.
Old 01-28-2015, 01:15 PM
Color: green
Rep:657
wr986 kind of like an early battery almost dead warning. SEMPER FI!
Old 01-28-2015, 03:29 PM
wr986's Avatar
Like a real loud idiot light
