Old 01-24-2016, 09:10 PM
Cisco209 Cisco209 is offline
Vehicle: 2009 ram 1500
Trim Level: Big Horn SLT
Color: Austin Tan Pearl Coat
Cisco209 is on a distinguished road
Default 2009 ram 1500 weight shift under load
Hey guys I'm having an issue with what feels like torque steer whenever I am on the freeway (most apparent) I will be coasting but as soon as I give some throttle between 45-100% the truck pulls to one side when I get off the throttle it lurches in the other direction. Sometimes I find myself turning the wheel to the right even when going on a slight left turn on the freeway. Any ideas on what could cause this? No lift all stock.
Old 01-24-2016, 09:52 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:251
Ramzaq is a jewel in the roughRamzaq is a jewel in the roughRamzaq is a jewel in the rough
Shocks, sway bar are two that come to mind.
How heavy is the load? Overloaded? Springs could be getting weak.
Old 01-24-2016, 11:49 PM
By load I mean engine load as throttle. I have been driving unloaded not towing when I feel this weight transfer. I know my front driver shock is leaking and is getting replaced in the next week or two when they come in. Could it be ball joints? or control arm bushings?
Old 01-25-2016, 04:16 PM
Rep:251
As you stated, bad shocks.
If you want better stability Hellwig makes a heavy duty sway bar for the 1500.
Old 01-27-2016, 03:44 AM
Yea I order 5100 bilstien shocks all the way around. Will try to level out the truck as well since its all stock also going to be installing the air lift 1000 helper springs soon just havent been able to install them. And yes the Hellwig sway bar was on my to-do list as well as beef up the rear sway bar. Seems I've been lucky with my truck as it has been very well equipped from factory. It has all the plug ins for stuff the laramie has standard.
Old 02-03-2016, 12:56 PM
NewfoundlandRam's Avatar
NewfoundlandRam NewfoundlandRam is offline
Vehicle: 2009 Dodge Ram
NewfoundlandRam is on a distinguished road
I am having a similar issue in my truck, sometimes it gets into a almost uncontrollable sway. Truck has 345,000km and I just had the rear end done under a recall by dodge. It did remove some of the problem, but I think I am going to try the rear control arm bushings next. But of course these bushings aren't replaceable and I need to purchase the whole arm
09 Ram 1500 Laramie, 94 Ford mustang, 03 HD Heritage softail, 08 Outlander xt 800, 08 Summit x 800r
Old 02-06-2016, 11:06 AM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
The Sound of Eight Hooves
Vehicle: 2013 Ram1500 4x4 8HP70 3.21LSD
Trim Level: Lone Star Quad Cab
Rep:616
Thunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to allThunderhorse is a name known to all
Surely someone makes polyurethane bushings by now so we have a better option than rubber OEMs
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Matte black Plasti-dipped center console bezel, BT catch can, Corsa 14405 cat back (video) Tuftruck 1223V progressive rear coils.
