Old 07-16-2013, 04:55 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
My IAC was also intermittent and not always a sure thing, except in colder weather it was a little more problematic. Yeah, I'm pretty sure the EGR has a solid port on the top that looks like they forgot to finish it for a vacuum line.
You can try unplugging the IAC and see if it reproduces the effect of when its acting up. If you unplug it and you feel what you feel when its acting up, then there you have it. However, it's not always an accurate determination because it may be open when you unplug it, but when it's malfunctioning, it may be closed. So it might fool you into believing it's not the problem.
I'm really sorry if that sounds confusing.
Old 07-18-2013, 03:05 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Jumped timing chain would not give intermittant problems. Hate to invoke my old favorite, but when in doubt, I always go to the intake plenum gasket when symptoms like this appear. Also, using any oil? That can also indicate plenum gasket failure. When it fails, it's one helluva vacuum leak.
Old 07-23-2013, 01:20 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
Agreed on the IAC and Plenum potential. Much easier to just replace the IAC. Also, what brand and age are the O2 sensors?
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 07-25-2013, 08:13 PM
thundersminions13 thundersminions13 is offline
Vehicle: 1995 Dodge Ram 1500
Color: Red/Black
thundersminions13 is on a distinguished road
update: we had a heat wave last week so left the truck alone since it was too hot to work on it. another vacuum line was changed - one to the EGR. it ran ok, not great, but got the job done last weekend. the IAC was removed and cleaned this week, and put back in. it made very little difference. it still idles rough, but i can deal with that. now we have a new issue. going down the road, it shutters with a clunk. it seems like the tranny disengaging and reengaging on its own for no apparent reason, other than its a dodge. the truck is at least usable and im happy with that
Old 07-25-2013, 08:32 PM
Color: Red/Black
to address the plenum questions: yes, it uses oil, but its nearly got 400 000 km on it. but i will take the cheap way out of the plenum and get gasket goop and smear it all around the intake - like we have done on the classic chevs. for the 02 sensor, its stock, but was cleaned last year when the exhaust was changed front to back. could not get the 02 sensor out of the old exhaust, so just cut it out and welded it onto the new exhaust.
Old 07-29-2013, 12:29 PM
Color: Red/Black
figures, the day the mechanic takes it for a drive it acts just fine! he says he would trust the truck. i dont. i wont go more than an hour from home and i wont go into the city where its all stop and go traffic. no wide open roads either. and i have 2 tow companies numbers in my cellphone now. drive it till it dies, then replace seems to be the answer here. rough idle i can handle. if the tranny keeps acting up and blows the pinion in the rear end out, i quit entirely. i know the pinion is wearing out. the shocks are also beyond gone and 1 is about to break off on the front. tried to repair the bolt bushing on it but the bolt wouldnt come undone. the sticker is good for another year on the plate. its falling apart and im not made of money to repair everything that it needs and i can not be without a truck having a dog kennel. i picked up a second job to pay off the plastic from the past few months of repairs. i appreciate everyone's help on getting the engine running better to keep it on the road for a bit longer
