Old 07-16-2013, 01:17 AM
admiralforever's Avatar
admiralforever admiralforever is offline
Vehicle: 2012 RAM 1500
Trim Level: 1500 Express CC
Color: Tequila Sunrise
Rep:19
admiralforever is on a distinguished road
Default trailer for towing
I don't know if I am posting in the correct area. I have a 2012 Ram 1500 CC with the Hemi. I have a class IV hitch on it. I need to tow my 06 AWD Pathfinder from Central Texas to Chattanooga TN. What trailer rental place do you guys recommend?
Old 07-16-2013, 03:17 AM
scrappy scrappy is offline
Vehicle: '12 ram 3500
Trim Level: laramie limited
Color: mineral grey
Rep:29
scrappy is on a distinguished road
good luck, the last time I tried to haul a vehicle ('00 durango) with my 3500, UHaul would not rent me a trailer since according to them "my truck isn't big enough"!
don't tell them what you are hauling or you won't be able to rent one.
But at the same time you are probably going to be overweight.
Old 07-16-2013, 04:14 AM
Trim Level: sport
Color: green
Rep:643
where else can he rent a trailer? would a tow bar be better?
Old 07-16-2013, 08:15 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Rent a car trailer from Uhaul or Ryder they have the trailer you need. do a Google search to see who is closer to you.
you connect it to you truck then ride the other one up on it and secure it. Good to go.
They are called Auto transport Trailers. see the link hope this helps you out give us a heads up on your solution
http://www.uhaul.com/Reservations/Eq....aspx?model=AT
or
https://www.google.com/search?q=rent...hrome&ie=UTF-8
Old 07-16-2013, 06:57 PM
Rep:19
I tried Uhaul but their trailer is too small for the weight of my Pathfinder. I can't flat tow the Pathfinder because its AWD unless I pull drive shafts off from it. I haven't tried Ryder yet.
Old 07-17-2013, 02:27 AM
JMS4218 JMS4218 is offline
Vehicle: 2014 Ram Sport crew cab
Color: Blue streak pearl
Rep:83
JMS4218 will become famous soon enough
The u haul trailer can handle 5200 pounds and you pathfinder weighs about 5000. So you should be good to go.
Old 07-17-2013, 03:07 AM
Rep:19
Uhaul said no, my RAM is equipped with a class IV hitch so it can easily pull 9000 lbs. But I guess the weight of the Pathfinder and the trailer will be too much for the coupler on the trailer.
Old 07-17-2013, 10:06 AM
Rep:83
That makes no sence as they say on their website the weight the trailer can handle. I would rent one and not tell them what you are putting on it and if they ask just say a small car of some sort.
Old 07-17-2013, 10:33 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
The last I checked, a 2006 OffRoad 4x4 V6 Pathfinder had a curb weight of 4373lbs. Your UHaul guys don't know their trailers bud. Bunch of rookies I tell ya. Even their Auto Transport Rental website under vehicle requirements clearly indicate your Ram is more than capable.
Old 07-17-2013, 10:35 AM
Gantman's Avatar
Rep:974
Yeah I agree with you man. Tell them tards at UHaul that your towing a Honda CRX with twin turbos.
