Problem with my Ram - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > MOPAR NATION - Dodge Ram Club Regional Chapters! > Dodge Ram Forum CANADA
Old 08-23-2013, 07:10 PM
TheCanadian TheCanadian is offline
Vehicle: 1998 Dodge Ram 1500
TheCanadian is on a distinguished road
Default Problem with my Ram
Hey guys Im new to this site to see if I can find some advice on what might be the problem with my truck. I was driving my truck one day and the truck randomly died on me and would not start up for about 5 minutes, so I figured that if I change the fuel pump that would solve the problem. After I changed the fuel pump the truck stopped dying on me, but the truck is now bogging, and back firing through the intake, and out the exhaust. I have changed the spark plugs, wires O2 sensors, and punched the cat, and nothing is working to fix this problem. I drive a 1998 Ram 1500 5.2L RWD, and I am hoping that someone here has the answer for me to fix this problem, please comment or private message me what you think and reasons that it would cause this problem Thanks alot.
Old 08-23-2013, 07:55 PM
FeedMetal's Avatar
FeedMetal FeedMetal is offline
Color: Maximum Steel Metallic
Rep:83
FeedMetal will become famous soon enough
2nd gen rams are good for fuel pump issues. bc of the collapsible pump. could maybe just be fuel pump again
'13 Sport Crew Cab / Hemi / 6-Speed / 3.55 / Anti-Spin - aFe Stage II CAI - MF 14" Muffler - BP 87mm TB - BP Catch Can
Old 08-23-2013, 08:11 PM
I was thinking that as well because were the sock is on the pump its located on the bottom of the pump so I was thinking maybe the pump is sitting on the bottom of the tank and not letting fuel pump up, could that be possible ?
Old 08-23-2013, 10:27 PM
FeedMetal's Avatar
Rep:83
could also be stuck at the top and extending/retracting back down to the bottom. the fuel pump is retractable like the little kid light swords lol. might be getting stuck
does it happen with a full tank of gas?
Old 08-24-2013, 09:45 AM
I havent tried it with a full tank of gas, because if it still does it thats gonna be a b*tch to change the pump, i have a new one on order and im going to try that first off
Old 08-24-2013, 10:42 AM
Calgary Canuk's Avatar
Calgary Canuk Calgary Canuk is offline
Vehicle: 2014 Dodge Ram
Calgary Canuk is on a distinguished road
Not sure if this would be a similar issue or not but I had a 97 dodge ram SS/T , that did the same thing outa the blue in 2006 , found out it was bad fuel , dealer emptied the gas tank and we refilled with premium and never had a issue again , when it happen I changed pump , battery , spark plugs ect. to no avail finally went to dealership and tada changed the gas out and no issues after that
Old 08-25-2013, 08:59 PM
really, never thought, that would cause it to back fire and all this sh*t to happen. maybe ill empty the tank into a jerry can and go grab some new stuff and try that out, im getting a new pump tomorrow because Ive heard from some people now including on this site that there was a bad batch of pump made awhile ago and the garage i heard this from had the same problem when they were installing them, and during the time it was happening to them they switched their supplier and they never had the problem again. Thanks alot guys hopefully both these suggestions fix this problem will repost tomorrow and let you know if it works.
Old 09-12-2013, 10:43 PM
Tot202's Avatar
Tot202 Tot202 is offline
Vehicle: 1999 dodge ram 4x4
Trim Level: laramie slt
Color: flame red
Rep:19
Tot202 is on a distinguished road
Try checking your crankshaft position sensor had same issue with the 95 dodge ram i had would suddenly stall truck and or back fire found out the sensor was just giving a faulty signal replaced and it went back to normal
Old 09-16-2013, 04:42 PM
Chunkem's Avatar
Chunkem Chunkem is offline
Trim Level: Longhorn Rambox
Rep:1648
Any update on how things are working out??
