Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-16-2013, 03:49 PM
ZX10R Ninja ZX10R Ninja is offline
Vehicle: 2004 Dodge Ram 1500
ZX10R Ninja is on a distinguished road
Default Blower Fan works intermittently
Been using the search feature here and only found a couple of post from 2011 & 2012 but didn't answer my question.
I have a Gen 3 2004 1500 Quad cab.
The blower fan works intermittently but even when working,not on high.
I've read something about the resistor and or the blower motor.
If anyone has any info on this subject, please include specific info,
such as where said items are located.
Old 07-16-2013, 03:54 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
This is the 2nd Gen Section (94-01). However, I believe it's still located on the passenger's side floor well.
If you're sitting in the passenger's seat, lift your left foot and the plug should be by your toes.
I also believe that there's 5/6 wires going into the plug and the resistor is held in with 2-7mm nuts/screws. When you drop it (goes in from the bottom-up) It should be a small green circuit board or a ceramic square.
Take a look and let me know.
Old 07-21-2013, 10:14 PM
dasbootwaffle's Avatar
dasbootwaffle dasbootwaffle is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: SLT extended cab
dasbootwaffle is on a distinguished road
Default Thanks for the tip (3 years later)
I knew I could find help here.
