2008 Ram 4.7L - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 07-16-2013, 07:42 PM
Rumpirate84 Rumpirate84 is offline
Vehicle: 2008 Dodge Ram V8 4.7L
Rumpirate84 is on a distinguished road
Default 2008 Ram 4.7L
I have been experiencing some ticking/knocking sound in the front right of my truck. It only happens when I am in idle at a stop light and the car is in drive. When I put the truck into Nuetral or Drive the sound goes away. my buddy said this may be tie end rods that may need worked on. Any ideas or suggestions on what to do?
Old 07-17-2013, 05:46 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Tie rod ends? You mean those metal, tubular pieces that connect to and turn the knuckle? If you are sitting, I don't see how the tie rod ends would make noise. By putting it in neutral you're taking the load off the suspension, but I still don't see how that would affect the tie rod ends if you're not moving. Now if you were moving and turning, then maybe. Does it tick in park? I'm thinking you've got a something going on with the tranny. I know little to nothing about them, so I won't even begin to guess. Have you got out of the truck and listened to verify that the noise is coming from the right front?
Old 07-17-2013, 06:08 PM
Detroit3000's Avatar
Detroit3000 Detroit3000 is offline
Vehicle: 2009
Trim Level: Big horn
Color: Brilliant Black Crystal Pearlcoat
Rep:68
Detroit3000 will become famous soon enough
I have that same issue, it's been driving me nuts. Mines still under powertrain warranty but I've hadn't had time to take it in. I notice it plain as day, others say they don't hear anything. A light knock barley heard over the engine noise and as soon as I put it in gear it stops. Sounds like it coming from the drivers side down low
