payload question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 07-16-2013, 08:33 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
Default payload question
im needing to go pick up a load of crush stone with my truck tomorrow.... wondering how much i can carry in the box without doing any damage... online it says 1600lb but that seams a bit high.... and ideas.... i do have a 10'' lift i dont think that should effect it any. thanks
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 07-16-2013, 08:38 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Honestly 1600 lbs is not much at all. You'd be surprised at how little gravel you get for that weight. One cubic yard (approx one scoop) of gravel weights around 2800 lbs. Depending on how far you need to travel with the gravel I wouldn't be too worried about putting a whole scoop in your truck. If you have to go a long ways then half a scoop at a time may be a better idea.
Old 07-16-2013, 09:12 PM
chadster21's Avatar
Rep:108
im pretty familiar with gravel and dirt weights being in the minning industry, im just wonderin if anyone has had an experience with a certain weight thats all.. thanks for your hep tho
Old 07-16-2013, 09:22 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I've put 1,500-2,000 lb in my truck on a several occasions and it pretty much fully compresses the suspension but it is ok. Just drive very easy and carefully. The payload for my truck is listed as 1,650lb. Remember payload includes passengers and stuff in the cab too. I go by the look of the suspension. Once you hit the bump stops, that's it lol.
Sean
Old 07-18-2013, 11:02 AM
chadster21's Avatar
Rep:108
lol i ended up putting 1 ton of rock in it. she was squat pretty good but i was impressed with how well she took it
Old 07-18-2013, 11:54 AM
Moderator
Rep:2140
Good stuff man! Did you happen to take any pictures with that much weight in the bed to show how much it was squatting?
Old 07-18-2013, 05:40 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1230
I have had lots of heavy stuff in my truck, including a load of rock which I had to weigh to get paid. Came in at 3k. No pics, but I have TLC anyway so you wouldnt see much. Well over the payload, but with just 10lbs of air in my bags she was level and drove beautifully.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 07-18-2013, 06:04 PM
Rep:2946
some people like to load a bit too much on a 1/2 ton
1 ton is usually ok, if you are careful
this guy may have over done it
http://www.ctsblog.net/2011/01/indep...ension-or.html
Old 07-18-2013, 06:05 PM
Moderator
Rep:2140
Nah, he's still good ^^ He's just taking that cambered tire look to the extreme
Old 07-18-2013, 08:54 PM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
Just be careful. God forbid something happens and your overloaded you could be found at fault regardless, people seem to forget that nasty little catch. Might be best to just rent a trailer and get all you need in one load.
Just Got it, Give me time!
