ZDOG
Old 07-17-2013, 09:04 AM
AirmenVader AirmenVader is offline
Vehicle: 2011 Ram 1500
Color: Grey
AirmenVader is on a distinguished road
Default Steering squeaking noise
Hey, I'm new to this forum. I have a problem on my 2011 Ram 1500. I notice a squeaking noise when I turn my steering wheel all the way to the right where I can't turn it anymore. What would that be? Any help would be great. Thank you!
Old 07-17-2013, 05:35 PM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Squeaking noise is coming from column, wheel well, wheel, ??? Does it squeak when your are moving, not moving, accelerating, braking, ???
Old 07-17-2013, 05:41 PM
Color: Grey
The noise sounds like it comes from the belt itself. It only does it every now and then. It happens when it's moving or not, but it only squeaks when it's at extreme steering.
Old 07-18-2013, 12:09 AM
Rep:2968
OK, so it's coming from the belt. You've got a 2011, and it only happens at he lock. OK, here's your issue. When you turn your steering wheel all the way, or to the lock, the pump goes in to bypass mode, meaning it no longer pumps power steering fluid in to the rack, but back into itself. This creates more drag on the belt and with a warn belt, it's gonna squeak a bit. Check your belt and see if you have any cracks in it. I know it's a cliche', but I'm gonna say it anyway. If your belt is warn a bit, then the squeak you hear is normal. Change your belt and I bet dollars to peso's that the squeak goes away.
Old 07-18-2013, 07:31 AM
Color: Grey
Thank you so much. I will check that out when I get off from work today. I think that's the problem as well. I just wasn't sure.
Old 07-18-2013, 09:00 AM
Rep:2968
You're welcome, my friend. That's what this forum is all about. Where 'bouts in Texas are you at?
Old 07-18-2013, 10:36 AM
Color: Grey
I'm station at Dyess afb in Abilene. I'm fairly new to this area, came from Arizona.
Old 07-18-2013, 12:32 PM
Rep:2968
Thank you for your service, Pak! Make sure you submit a request to get a military badge.
You'll find the Texas heat just a bit different from the Arizona heat. In Abilene it won't be as bad as the Dallas area, and no where near the soggyness of Houston, but you'll get a little bit of humidity and man does it suck!
Old 07-18-2013, 05:41 PM
Trim Level: sport
Color: green
Rep:682
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i always back off a bit a wheel lock, no noise, no excess wear and tear.
Old 07-18-2013, 10:06 PM
Rep:2968
Excellent advice! I do the same.
