United Radio
Old 07-14-2013, 10:25 AM
dazeoff21 dazeoff21 is offline
Vehicle: 2011 Ram
dazeoff21 is on a distinguished road
Default Question about wheels
I have a 2011 4x4 with 265/65/17 wheels and tires. A friend has a set of 225/60/18 5 lug chrome wheels and new tires for sale. They came off a 2006 model. My questions is will they fit my 2011 and is 450.00 a good price. Thanks in advance for your response
Old 07-14-2013, 11:45 AM
Color: green
Rep:632
too much of a s, size difference imho. not something i would do.
Old 07-14-2013, 07:38 PM
Lifted Cummins Fanatic
Rep:1969
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
Ya, I personally don't know why you'd want to put tires that small on your truck....
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | 4.56 AAM/Yukon Gears | S&B Intake w/ Scoop
Old 07-17-2013, 06:40 AM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default Buying these tires/wheels
Just some thoughts:
a. The overall tire diameter would be approximately the same since they
are a lower aspect ratio than yours. Also this may create a tiny speedo
error.
b. 60's will ride a bit rougher than 65's will since there is less cushion
effect.
c. Friend's tires are 1.57 inches less wide than yours. Would you be
satisfied with skinny tire look?
d. Unless your friend just can't use them anymore, I'd have to ask myself
why does he want to get rid of them.
e. Unless you were planning to buy new tires anyway, and/or just like the
wheels, why do this at all?
f. I would want tires with the same load carrying capacity, have you
compared this information with what's on both sidewalls? I would
suspect that your truck's recommended inflation pressure is not going
to be the same if you change out.
g. Good price?,...it depends on what kind of tires you'd be buying such as
expected tire mileage, temperature and traction ratings, road noise,
etc. Also are they of similar quality or a grade lower?
h. It has always been my opinion that the factory engineers who spec'd
out a new vehicle know what is the best combination for fitment and
performance.
I. Just me, but I'd re-examine my reasons for considering this
purchase,..is it a real need?, just like the idea of bigger wheels?,
remember too that you would be stuck with buying this tire size in the
future. Again, just my personal recommendation, I'd rather see you
bank the money and purchase the correct tire size and quality when
you need replacement.
By the way, I worked at Michelin Tire for 28 years, so I will claim to posses some small knowledge of tires, performance and fitment. I presume that you have confirmed bolt patterns, wheel offset and runout. Please make your choice based on the above mentioned factors. And finally, if I may suggest so, don't do it.
Old 07-17-2013, 06:46 AM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
Don't do it..... those tires will look rediculous. Anyway what's the. Offset
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 07-17-2013, 01:27 PM
terry littlejohn terry littlejohn is offline
Vehicle: 2011 ram 1500 4x4
terry littlejohn is on a distinguished road
I think in the mid 90`s they went from 5x5 pattern to 5x5.5 pattern,so I think the 06 should be the same. are they after market wheel?
Old 07-17-2013, 10:04 PM
Rep:1385
3rd and 4th gen rams have the same bolt pattern.
I agree they will look ridiculous.
