4.7L Catch can install help! - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 07-17-2013, 05:06 PM
Asur Asur is offline
Vehicle: .
Rep:4373
the hard plastic tube is located between the PVC Valve and the Intake, you will need to pull that tube off and cut it away from the PVC Valve, then attach Vapor hose to the plastic tube on one side and plug that back behind the intake, and the PVC Valve you cut away from the plastic tube you will need to remove the left over plastic tube piece from the PVC Valve and attach another Vapor tube to that PVC vlave, install both pieces to the engine and turn the 2 new Vapor tubes to the Catch can, you basically cutting into and putting in between the PVC Valve and the intake Plastic tube your catch can. Hope I explained that right
Old 07-17-2013, 05:08 PM
pstreifel's Avatar
pstreifel pstreifel is offline
Vehicle: 2012 Dodge Ram 1500
Rep:34
pstreifel is on a distinguished road
Disregard last question I thought you mean buy it when you said you will need to but it. You meant "cut it" I had to read it a few times to get that.
Lift 'em high because fat girls can't climb!
Old 07-17-2013, 05:14 PM
Vehicle: .
Rep:4373
Hope this helps
Old 07-17-2013, 05:17 PM
pstreifel's Avatar
Rep:34
That is exactly what I needed ! I really appreciate your help!
Old 07-17-2013, 05:20 PM
Vehicle: .
Rep:4373
No problem .....
Old 07-17-2013, 08:29 PM
pstreifel's Avatar
Rep:34
I finished it and it really wasn't that hard. It just took the most time to find out the best way to mount the can! I don't know if you had the same problem but the hard plastic hose was too small for the half inch adapter so I just slid the hose on top of the hard plastic one. Then I used a hose clamp to make sure it wouldn't slide off. For mounting I got an L bracket from Lowes and did a little bending to get it in the right position. I then cut a little piece of plastic from the battery base plate right next to the fuse box and put 2 bolts in it. I was able to utilize the bracket that came with the BT can also with that L bracket. I will post some pictures shortly!
Old 07-17-2013, 09:00 PM
pstreifel's Avatar
Rep:34
Here it is finished!
Old 07-17-2013, 09:37 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
For any others interested, this Moroso 85472 should be a direct bolt up for both 4.7L and 5.7L rams (4th gens):
http://www.ebay.com/itm/Moroso-Oil-C...-/121144895253
http://www.gpmm.org/showthread.php?t=3913
You'll just need extra hose.
Sean
Old 07-17-2013, 09:51 PM
Vehicle: .
Rep:4373
Sweet, nice, reps for sharing some pics
Old 07-18-2013, 09:11 AM
pstreifel's Avatar
Rep:34
Thank You. Thanks For reps Also!
