Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-18-2013, 12:59 AM
dschutz1979 dschutz1979 is offline
Vehicle: 1987 dodge d150
Trim Level: le 150
Color: red and white
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
dschutz1979 is on a distinguished road
Default key
when i got to work today i went to turn the truck off and the keys wouldnt turn. they are stuck in the on postion. wont turn to off or start. any ideas?
Old 07-18-2013, 12:23 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
have you tried pulling the shifter up? i know occasionally i will have to pull the shifter up for it to let the key turn all the way back.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 07-18-2013, 12:42 PM
Trim Level: le 150
theres a electrical box that has a rod going from it to the key. i think its froze up. where tje rod goes into it wont slide. plastic aroumd one of the connectors is melted.
Old 07-18-2013, 01:16 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
That's the ignition switch.
Is the wheel locked? The switch isn't very expensive. The two thick red wires (maybe purple with a black tracer) should be the power/start to crank the engine. If you can find the power on (smaller wire I forget which color) and jump it to get the dash to light up, jump the two red wires to crank in and start it.
Pull the first smaller jumper wire to shut it down.
Old 07-18-2013, 01:20 PM
Trim Level: le 150
theres a box under the dash that the rod goes to and its melted and wont slid. do you know what tjat box is called?
Old 07-18-2013, 01:27 PM
Trim Level: le 150
nevermind it is a switch. found it on advanced auto website. its not as expensive as i thought. its only $22. thats for the help.
Old 07-18-2013, 01:33 PM
Vehicle: 95
Rep:1776
When you install it, unhook the battery. Remove the 2 nuts/bolts that hold it on, unplug it (Lift the lock tabs).
When re-installing, leave the plug till last. Center the switch over the rod and then slide it (it'll be springy (springy is a technical term)). Line up the bolt holes and install them. then plug it in last.
This way the truck doesn't try to start during the installation.
