Old 07-18-2013, 10:07 AM
jfreakofkorn jfreakofkorn is offline
Vehicle: 2001 Dodge Ram
jfreakofkorn is on a distinguished road
Default 01 dodge ram w/ a wire hanging ....
just had my trans rebuilt n replaced the engine in while i was at it ( finally ) ...
now putting everything together and got stumped ...
there is this one wrire from the drive side innner fender ( some kind of fuse board w/ a cover it it next to the battery ) is running down next to the starter ....
its black and loom on it w/ a bolt hole kind of circle connector ( at where a bolt goes thru it ) at the end ....
is this some kind of ground .....???? and where does it getting bolted down tooo .....
can anyone help with this situation ....
thanks for lookin n have a nice day
Old 07-18-2013, 04:14 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
You're totally screwed, Dood! The flux capacitor will not achieve enough... ok, I'll stop there.
How about a picture of it. Sounds like an engine ground, though. Is everything working? What, exactly, is the attached end attached to?
Old 07-18-2013, 04:29 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
DOC! You forgot to ask him if he can tell if it goes to the positive or the negative side of the battery!
Great Scott! does it have power? Is it the trigger wire for the starter?
Old 07-18-2013, 10:13 PM
Rep:2929
Hey, ah, kornflakes... I'm sorry, jfreakofkorn. Can you tell if it goes to the positive or the negative side of the battery? Does it have power? Is it the trigger wire for the starter?
Phew... I feel so much better now. Gonna have a good night's sleep tonight!
Thanks for the laugh, Drew!
Old 07-19-2013, 09:02 AM
this is what i took after work at my other job
where does this go or attaches to ...
Old 07-19-2013, 09:08 AM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
Looks to me like a chassis or a Batt terminal ground. where does the other end go; which terminal on the starter?
Old 07-19-2013, 09:48 AM
2nd photo right above the red wire in the photo ...
their is this box and its attached to that ....
looks like its two wires on one terminal
Old 07-21-2013, 01:30 PM
i added some more photo(s) of i dont know ...
the first photo is on the driver side. it has two plugs and i have no clue at where to go .. one is near the middle of the engine and the other one is in the rear of the engine close to the brake booster ...
the second is a closer photo of the other plug near brake booster
the third is passenger side valve cover. i dont have a clue at what goes here or at where it runs too ....
final the fourth is on the the passenger side. some vacuum lines that has a small diameter fitting and where do they go is ....???
Old 07-21-2013, 01:47 PM
Vehicle: 95
Rep:1776
Photo 2, post #5 looks like it's going down to the eyelet for the engine ground (see below) and back up to the power distribution center under the hook completing the engine/body ground.
Photo 3, Post #5 Looks to me like it's coming off the BLACK/negative side of the battery and would be an engine ground mounted on one of the starter mounting bolts.
Photo 1, post #9 looks like the oil pressure switch.
