Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
tonneaucovered.com
Old 07-18-2013, 12:01 PM
Jmania44's Avatar
Jmania44 Jmania44 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Big horn
Color: Green
Jmania44 is on a distinguished road
Default Front shock chirping
Ok so a week or two ago my front passenger side started making this high pitched chirping noise when I'm coasting down the road. It sounds like a metal on metal sliding against each other. I can bounce on the front end and it sounds like its coming from the shock. When it gets wet it stops. I've sprayed everything down with grease and can't make it stop but if I spray it with water in the shock area it stops. How do you tighten down the shock tower or is there something else someone who has had this problem knows what I can do.
Old 08-04-2013, 09:23 PM
bseling's Avatar
bseling bseling is offline
Vehicle: 2011 RAM 1500 Crew Sport 4x4
Rep:60
bseling will become famous soon enough
My truck is having a similar issue. When going over any small bump, something squeaks...
I took it to a dealer near my house and they basically gave up and said "noises arent covered under warranty".... Not really a good response if you ask me...
Anyone else have a similar problem? Should I go to another dealer? I have 34,500 miles on my truck, so I'm getting awfully close to the magic 36k... I find this very frustrating.
Old 09-01-2013, 12:59 AM
ramfan1500 ramfan1500 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: trx
Rep:63
ramfan1500 will become famous soon enough
my truck has 32,000 miles and i have the squeak when going over small bumps, cant figure it out. I hope someone has found the solution to this
Old 09-03-2013, 10:27 PM
bseling's Avatar
Rep:60
So I finally got the dealership to replace the two front shocks under warranty, and after a week, I think I am convinced that the squeak is gone! I'll repost if it comes back (God forbid!)
Old 09-23-2013, 12:37 PM
Joem Joem is offline
Vehicle: 2013 Ram 2500
Trim Level: Crew Cab Laramie
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 320hp 650lb/ft (Chassis Cab)
Joem is on a distinguished road
I get a metal clunk sound when going over speed bumps. Dealer said they don't hear anything and I'm at 34,000 as well going to a different dealer to get it looked at. The outlet connected to the batt also did not work until they had it then it was fine for two days and now it doesn't work again!
Old 09-23-2013, 10:52 PM
hoyter hoyter is offline
Vehicle: '11 1500 sport 4x4
Trim Level: sport 4x4
Color: mineral grey
Rep:13
hoyter is on a distinguished road
I had a similar metal clunk from the drivers side front when hitting bumps with some feeling in the pedals. After two new shocks, they replaced the caliper. The work notes stated they were unable to torque it to spec. The noise stopped immediately. I guess maybe it was rattling around a bit.
Old 10-03-2013, 08:19 PM
Windbane's Avatar
Windbane Windbane is offline
Vehicle: 2014 RAM 1500 Sport
Color: Maximum Metallic
Windbane is on a distinguished road
I have the same squeaking/chirping sound, haven't brought it to the dealer yet. Seems to happen at random times, so far I only hear it on rough dirt roads (the suspension sounds really loud on the rough stuff too). I also noticed today that I have alot of, I'm guessing, brake dust on the front drivers side rim. So maybe the noise is a brake issue?
Old 10-11-2013, 12:35 PM
Well I took mine to another dealer and it turned out the bolts holding the frame to the body were missing in the front!!! It was fixed and sounded fine the rest of the day, but I traded it for a new 14 the next day.
Old 10-19-2013, 02:06 PM
07HDram 07HDram is offline
Vehicle: 2007 Ram 2500 4X4
07HDram is on a distinguished road
I had a similar chirpy squeak when I went over small bumps in the road. I replaced my shocks, ball joints and axle u-joints and still had the issue. finally ended up spraying down the top and bottom of my coil springs with PB Blaster and the noise went away. Its been 4 months and its still going strong. It's worth a shot.
Old 03-25-2014, 09:05 AM
BENLOCO BENLOCO is offline
Vehicle: 2013 RAM 1500 SLT 4x4
Color: silver
Rep:31
BENLOCO is on a distinguished road
i had the chirping coming from right hand side of my truck. i replaced the front shocks and struts and the problem is still there! its very anoying and somebody better find a soulution. its driveing me insane.
