Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
tonneaucovered.com
Old 07-18-2013, 04:58 PM
89powerram's Avatar
89powerram 89powerram is offline
Vehicle: 2004 dodge ram 1500 hemi 4x4
Trim Level: Slt
89powerram is on a distinguished road
Default Low oil pressure
So I got on it today on the highway and right after that my check gauges light come on and my oil pressure was at L and it would come up to normal the. Go back down again I pulled over and turned the truck off started it back up again and it ain't come back on what is the deal
-IF YOU CANT DODGE IT RAM IT!!!!
Old 07-18-2013, 05:54 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
did you check the oil level? if it's ok then it's possible the sender is going bad...
Old 07-18-2013, 05:55 PM
chefred112's Avatar
Rep:656
if you get a check guage light for low oil pressure, first thing to check is if you have oil...
Old 07-18-2013, 07:36 PM
89powerram's Avatar
Trim Level: Slt
The truck runs fine and the light only comes on whe. I hammer it
Old 07-18-2013, 09:22 PM
89powerram's Avatar
Trim Level: Slt
Drove it home with the pedal on the floor damn this thing will run lol but it hasn't came back on and the oil pressure has stayed in the middle of the guage (knock on wood) idk what happend before
Old 07-19-2013, 10:28 AM
chefred112's Avatar
Rep:656
you haven't told us if you have checked the oil level...this is kinda important.. almost sounds like at normal driving, oil level is enough to reach oil pump, when you hammer it, the centrifugal force is pushing the oil rearward. Oil pump is located at front of motor so there is a chance that oil level is low enough that none is getting to pump when you hit it..
Old 07-19-2013, 11:42 AM
89powerram's Avatar
Trim Level: Slt
The oil level was fine slightly overfilled
Old 07-19-2013, 07:33 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
Maybe junk in the pan? when you hit it the increased suction grabbed something in the pan temporary blocking oil pick up? or the pick up tube is bent and is sucking the bottom of the pan? I don't know I personally have never looked and the bottom end of the hemi with the pan off. Just my two cents.
Old 07-19-2013, 11:30 PM
89powerram's Avatar
Trim Level: Slt
Well I noticed it only does it at like 90 degrees outside temp So I looked at the air temp sensor it was BAD dirty and my battery cables were really corroded so I wondering if that had anything to do with my other electrical problems
