Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 07-18-2013, 08:30 PM
rangerrock rangerrock is offline
Vehicle: 2001
rangerrock is on a distinguished road
Default freon leak
i am the original owner of a 2001 ram 4x4,with a 5.9 gas engine.
it is a 1/2 ton with an auto trans
it has 149,000 original miles
the a/c system is completely original except for the hose assembly was replaced
with a dealer part about 5 years ago
it will not hold a freon charge anymore
Where is the first place a leak could be???
Old 07-18-2013, 08:36 PM
Rep:2616
there is a special dye that is used to find A/C leaks
Old 07-19-2013, 02:37 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
main seal on the compressor is the overall most common. other than that really could be anywhere, condenser, evaporator, accumulator, and any of the connections. There's a UV dye used to pin point leaks.
Old 08-02-2013, 05:07 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
I'd check the ac hose assembly. I've had issues with mine. My factory one leaked, then I put a new one on from Rock Auto that was junk and leaked at the hose crimps and on top of the compressor. My new one seems to be doing ok.
But, you will need to use dye to find leaks, unless its just that bad. Also, the high pressure valve on mine wasn't sealing all the way and leaked as well.
