Old 07-27-2013, 11:48 PM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
Default Mopar splshguards
I opted for the Mopar splash guards. They have very good tire coverage with the stock wheels. The picture of the front shows with the Amp Research steps both open and closed.
Mods: Too many to list
Old 08-11-2013, 03:08 PM
Tom-G Tom-G is offline
Vehicle: 2013 RAM CC 4X4
Color: Blue
Rep:16
Tom-G is on a distinguished road
Default Mopar Front "Flat" Mud Flap - Part Number?
I have been looking at mud flaps and have settled on the Mopar flat rubber flaps. I have checked various Mopar OEM parts sites and for trucks without fender flares they list 2 sets of flaps but only for the rear of the 2013 1500 Rams:
2009 - 2013 Part # 82211267AB Rear with Ram Head and
2009 - 2013 Part # 82212290 Rear with Ram Head and Ram Logo
However nothing listed for the front for 2013! They do show the following plain (no logo) flat flap for 2012, but not 2013:
2009 - 2012 Part # 82211266AB Front
Has anyone installed the 82211266AB flaps on the front of a 2013 1500? If so, does it fit OK? Is it a no-drill installation just using the factory holes in the fender?
I'm planning on the "67AB" flaps for the rear. Can anyone confirm if they are no-drill installation?
Thanks.
Old 08-11-2013, 04:22 PM
tguil tguil is offline
Vehicle: 2012 Ram
Trim Level: Big Horn Quad Cab
Rep:45
tguil is on a distinguished road
No drill for the rear flaps if you choose to use only two out of the three mounting holes. I have mounted them using only the two holes and it works just fine. I filled the extra hole with black "plastic rubber".
For a tight fit on the front flaps, you need to drill the third hole. No problem at all doing this. You don't need to remove a wheel to do so. If you are worried about rust, don't worry. Put a dab of primer on the area after you drill the hole. The mounting screws are covered with a silicone seal that makes a tight rust proof bond.
2012 White Hemi 1500 QC, 4X4, Big Horn Edition, Protection Group, Luxury Group, 3.92 Anti-Spin, Mopar Bedliner, Mopar Tubular Side Steps, Mopar Molded Mud Guards, Access Roll Up Tonneau, Michelin LTX M/S 2's
Old 08-11-2013, 09:16 PM
Color: Blue
Rep:16
Did you use the "66AB"'s on the front?
Looks like I'll need to find different mud flaps for the front. They use a ton of road salt in the winter here and I really do not want to drill into the metal. When the salt spray from the highway dries we have crusted salt on the sides making our vehicles white!
I have factory side steps and no fender flares. What have the forum members been using for no-drill mud flaps on the front?
Old 08-11-2013, 10:06 PM
SteveA922 SteveA922 is offline
Vehicle: 2013 1500 Longhorn 6'4" bed
Trim Level: Longhorn
Rep:25
SteveA922 is on a distinguished road
Just installed the Husky Brand on my Longhorn (molded fenders). The fit is very good, no drill fronts and the rears use 2 factory screws plus you drill one per side. The 2 holes are both into the plastic wheel well liner and not into any steel. They cover the 1 inch over sized Michelin LTX AT2's LT275/65R20 nicely.
Old 08-24-2013, 06:49 PM
keonos keonos is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Grey
keonos is on a distinguished road
What part number did you buy? Do you have pics of the fit with flares?
Old 08-25-2013, 09:24 PM
Rep:25
I purchase the Husky's online from Amazon and the confirmed the part number on Husky's web site....easy to do. Can't get the pics to load, probably to large of an image.
Old 09-26-2013, 04:23 PM
faustus faustus is offline
Vehicle: 2013 RAM 1500 SLT V6 8 speed
faustus is on a distinguished road
I ordered the MOPAR Deluxe Molded Splash Guards for my 2013 RAM 1500 SLT, and I will get them installed by a friend.
I would have one question:
What kind of clear tape have you guys used in order to prevent the paint scratching? I am not very knowledgeable in this area ....
Can somebody point a newbie in the right direction ...?
Thanks.
https://www.fuelly.com/car/dodge/ram-1500/2013/faustus/207076
