Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2012 Dodge Ram Forum
Old 07-18-2013, 10:28 PM
DWWHemiguy's Avatar
DWWHemiguy DWWHemiguy is offline
Vehicle: 2012 Ram
Trim Level: Express Quad Cab
Rep:37
DWWHemiguy is on a distinguished road
Default Possible issue with DS Intune
Today I decided to bump up my throttle boost a little. I've changed it a few times before with no problems. When I did it today the tuner didn't seem to want to work correctly. After I made the throttle adjustment it wouldn't write it. Then it read " tuner in recovery mode". I re-tried again and it read "unable to write tune". After several attempts that failed I unplugged the tuner. Once plugged in again it had to re-write the original back up then I was able to write the 89 tune again. I test drove the truck and all is well. Has anyone else experienced anything like this? I've only flashed the pcm 5 to 7 times. Hope I didn't screw anything up.
